nate2909
- January 24, 2016
- Nw GA
- 2000 Ford Explorer 2wd
Ok it's a 2000 explorer 4.0 2wd. The transmission was rebuilt front to back. Valve body updated with the sonnax zip kit and new gaskets. Put back in and no reverse and no drive unless you go from d1 or d2 then to drive. I have drive if it's put into D1 or D2 and then straight into D. No codes. Reverse revs and makes the "clunk" but no movement. Can anyone help? Stuck valve or pressure issues? Oh and I can let it run and shift through all the gears and the fluid temp doesn't get up to temp.
