Mark in VA
- September 29, 2002
- Sandston, VA
- 00 Mercury Mounty E.B.
Hello Ladies and Gents, I have done a search and reading and now I am Looking for troubleshooting and diagnostic ideas before I start swapping parts. What are my next steps?
Here is what it is doing - the transmission does not "go into gear", the shifter lever and linkage move and the lever on the side of the trans case moves freely and 'clicks' into all PRND21 positions.
The driveshaft will not turn in any shifter positions, which I describe as the transmission itself locked or stuck on Park.
it is a 2000 Mercury Mountaineer Eddie Bauer AWD 4.0 V6 240,000 miles, about a year ago reverse gear went out - everything else worked fine. I swapped in a 'supposedly rebuilt' transmission that I ordered online from a transmission re-manufacturer. He was out of state, I don't remember who.
Due to life / weather / a dead fuel pump, the truck has sat idle for a year until I just got it running again last week.
Once started, it had a blinking OD light on the dash and the OBD scanner showed code P0705, bad transmission range sensor. I Replaced the TRS switch and we have no codes stored now.
Here is what I know:
Rebuilt ? transmission
New Torque Converter
New TRS switch - Engine starts with the shifter in P and N, reverse lights turn on in R
All electrical connectors are plugged in.
Engine runs good, and after several minutes everything comes up to proper operating range temperatures.
A.T. Fluid level is good, per the dipstick after adding 9 to 10 quarts of Mercon V.
Fluid flow is good through the cooler is good, I opened the upper (return) cooler line to start the flush process
The parking brake is not frozen, the Rear wheels will turn if I manually shift the transfer case to N.
Line Pressures at the test ports are good, and change (increase from 60psi to 120psi) with shifter position change to R.
Thanks for your consideration and thoughts - I open open to all ideas
