Solved - 5r55e lower dipstick leak | Ford Explorer Forums - Serious Explorations
Solved 5r55e lower dipstick leak
Lee's Automotive
Git-R-Done
Location
United States
Alabama
99 Explorer XLT 4.0 SOHC
Anyone know how this seals in a 5r55e transmission? it's leaking pretty good on mine
Look like a typical dipstick tube with seal. It should insert into tranny hole seal end side in. Push into place. And secure tube bolt.
There is no seal its just metal
I installed mine dry ....a new unit ....
Clean the hole in the trans with break clean on a clean rag
DO NOT SPRAY ANYTHING IN THE TRANSMISSION
Install my with a rubber o-ring
The upper dipstick has 2orings
I can wiggle this lower stick up and down left and right I tried rtv and it didn't work is there something I can do to stop this leak?
sure its inserted all the way? if so, which rtv did you use? not sure it makes a diff, but i used the blu rtv for oil, and needless to say, i needed yo redo that later on. maybe you could weld it? as in widen the end and weld together like exhaust? thinking outside the box here
Basically I don't want to drain this trans again I used the 90 minute Grey and it just keeps leaking
huh alright.... i suppose welding could work, shouldnt come loose after that! not sure htough, perhaps someone has a better idea!
Wonder if this would work?
If anyone else has this issue the part number is 6L5Z 7A160-A it was a pain in the rear to find it, but it's pressed in with Teflon
