5r55e main pressure problem | Ford Explorer Forums - Serious Explorations
cooldrool
medford or
i have a 1999 sport with 4.0 pushrod..5r55e...160k...my transmission a couple months ago under heavy throttle on a freeway onramp dropped into neutral between 3rd and 4th...ever since it kept on doing it....ive got so many projects in the garage i had to take it to a mechanic i know...from reading threads here we thought epc solenoid and valvebody gasket...he tested it and found pressure problems so all the solenoids and gaskets were done...but nothing fixed it....now could it be a valve body problem? [ the last affordable fix left] or the REBUILD?he says its low pressure in the main system..A pump or leak on the way to the EPC..THANKS for any help
