CAG8R
- December 17, 2006
- San Jose, CA
- 1999 Explorer EB 4X4
I have been reading for a couple days now and have not found my exact problem. I feel that the problem might be in the VB, but not sure. So I will explain what happened and see if any one has experienced this issue.
I have a 1999 Ford Explorer 4X4 4.0L. In February, 2006 my wife called me saying the truck was not shifting right and the rpm's were very high. She also said the O/D was flashing. I told her to pull over and wait for me. After arrival, I started the truck and noticed no flashing O/D light or any other issue. Therefore, I decided to drive it around for a while. I went less than a block and it sounded as if I threw a rod. Very loud noise sort of like a small explosion. Afterwards, it was as if I were in neutral. The engine was running normal, but no thrust at all. I drifted to the side of the road. The flashing O/D came back on. I tried every gear including reverse and nothing would happen. However, if I tried to put it in park with the engine running, it sounded horrible like I was trying to start an engine that was all ready running. So I would shut off the engine and put it in park. After trying for thirty minutes to get it to move unsuccessfully, I called the tow company. After a "bad" recommendation from a friend I had to towed to a local transmission company. Strange thing occurred then. After removing the truck from the flat bed, I was able to get it to go into all the gears and even drive it. It was shifting hard though. Therefore, I left it there to see what they suggested. They told me most likely the transmission would need to be rebuilt. However, after pulling the transmission they found nothing wrong and told me it was the transfer case causing the problem. They replaced the transfer case and reinstalled the transmission for the small fee of $2,500.00! It drove perfectly for the last ten months, and Walla exactly the same thing happened on Friday. Exactly the same thing even the part about unloading it from the flatbed. This time (nothing under warranty) I asked to just drop the pan for me. They said it was full of metal. I looked at what they called full of metal and question this. The magnet in the bottom of the pan did have metal particles on it, but I would say more like a fine powder. No signs of metallic pieces that I am more accustomed to seeing in a manual transmission. Note: I know nothing about automatics other than reading your great post on the valve body diary. I had him change the fluid and filter and drove it home. He told me that it needed a rebuild again, but I sure wasn't going to fall for that again. That led me to here. On the way home, I think I wound up in limp home mode. I could not drive over 55 mph as the RPM's were getting high nearly 5000. It felt to me, like it would not shift into third gear. It has been sitting in the garage since. Please enlighten me to any suggestions you might have. Thank you very much in advance!
