jonyjay2
- July 14, 2005
- Baltimore, MD
- '99 sport
Hi Everyone,
My wife has a '99 explorer sport 4.0L SOHC, 5R55E 5 speed A/T with 92,000 miles. For the past 6 months it has an intermitant erratic shift. At times it feels like the trans goes from 1st to 5th gear without winding out through the gears, and feels sluggish, like it is in a wrong (higher) gear. At very rare occations, it will engage twice in reverse when shifing in reverse, (done this once). The problem accurs when operating temprature is hot or cold, but mostly when it's been driven for a while. When this happens, the O/D light flashes, no "check engine" light, but no EEC-V trouble codes was set on the Snap-On scanner. The other day, the trans was shifting erratic, the "check engine" light came on for the first time and the O/D light flashed. This time trouble code P0733 (3rd gear ratio error) was set on the Snap-On scanner. I checked all the connections on the trans and the EEC-V prossesor, all connections and terminals are tight and free of dirt and corrosion. The trans fluid is red and not burnt or smells burnt, and filled to proper level.
About 60,000 miles, the trans had problems going into kick down (pasing gear). The ford dealer replaced the valve body under warranty.
My question,
What could be causing this?
EEC-V prossesor, solenoids, valve body?
I am leaning toward the prossesor because it never set any trouble codes untill 3 days ago.
I am familiar with automatic transmission repair/rebuilds.
Thanks in advance for any help & suggetions.
My question,
