5R55E problem | Ford Explorer Forums - Serious Explorations
5R55E problem
TOT97
Hokkaido
97 SOHC 4.0L
5r55e Need Help!!
Hello all,
I'm having a problem with 5R55E.
The problem is right before stop, I feel "bang" from trans aslo kicked back the brake.
I have checked with SCT Live, then it tells me that trans did not shift 3-2-1.
Mine was shifted 3-1. Is this normal?
I also feel bad with up shift in 1-2.
I have installed new separate plate and SUPERIOR KIT. Then it did nothing, so I have changed TPS.
But still I'm having same problem.
Does bad TCC solenoid cause this problem? Or other part I should look?
NEED SOME HELP!!
TOT97
97 SOHC 4.0L 5R55E : Japan
