EricB123
- August 28, 2017
- 2002 Mazda B4000
So I've put about 15k miles on this transmission that I rebuilt. It worked pretty well most of the time. I do have to back off the accelerator in the 2-3 transition for it to shift. I took it to a mechanic who test drove it and thought the problem was related to the valve body. I didn't rebuild the valve body other than change all the solenoids and wire harness, and gaskets. Someone had previously installed the shift kit, but everything looked ok.
Around 15k miles after a long heavy tow and drive -- nothing too heavy, just the first time up and down the mountain. All was good until I got to a light and when I went to accelerate it didn't want to engage, and then there was a shutter and it started to go.
Slowly it's been getting worse and sometimes shuttering in 3rd while driving. So I replaced the valve body and found the oil was dirtier than I expected. Unfortunately it seems to still have problems engaging.
Any thoughts on what this problem(s) would be?
Thanks for the help. This forum helped me last time during the rebuild a lot. I hope this one isn't too serious.
