cr125r847
- October 1, 2003
- Blooming Prairie, MN
- '99 XLT
This is my first try posting pics, so work with me if they do not show up.
I'm rebuilding a 5R55E from a 1999 explorer and wanted to share something interesting that I have found inside:
This pic is the end of the reverse servo piston shaft. The end of the shaft is almost completely chipped away, which ended up causing the transmission to go bad and many hard parts to get wrecked.
I bought a used reverse piston off Ebay and received this:
The end of this shaft is pitted and cracking, just like the one that was originally in the transmission.
I just wanted to give everyone a heads up to very closely inspect all of the parts that go back into the transmission when rebuilding it. Damaged parts like this could easily go unnoticed and cause the transmission to fail soon after rebuild.
One question that I have though, is some of the exploded diagrams of the 5R transmission show a spring under the reverse servo piston and some with no spring. Anyone have any information on this?
