stryder12
- February 10, 2016
- 2001 Mercury Mountaineer
Good morning all,
I am here in hopes of fixing my '01 Mountaineer 4x4 4.0L SOHC with 138,000 miles transmission issues. The shift flares have started recently though O/D light has never come on. In reading through the valve body diary thread (which is awesome by the way, thanks to all who have contributed to it) I have a good idea of what is needed for the fix, but there seems to be a lot of separate fixes done in conjunction with the shift flare fix, so it gets a little confusing.
To narrow down what exactly is needed (most likely, I still have not opened the trans but based on symptoms others have had and fixes used, I believe I have either a bad gasket or the EPC is going bad) to fix the shift flare only and not overhaul etc, could someone verify if I have the correct idea?
1. TransGo shift kit
2. A new EPC and other 5 solenoids (or are other 5 solenoids not important to replace?)
3. Upper and lower body separator plate gaskets
4. Mercon V ATF fluid (alot)
5. Cleaning fluid/rags etc
Are there any items I am missing that are required solely for the valve body shift kit fix? I feel like there might be another gasket set required but I'm not positive. Obviously I don't have the tools listed (torque wrench, Torx bolt sockets, etc) but I am aware of them and will have those as well.
I appreciate all the information you all have compiled on this site, it's an excellent resource and has already helped me fix the blank radio display and a few other smaller issues.
Cheers and thank you,
