5r55e shift position 97 ford ranger | Ford Explorer Forums - Serious Explorations
saling4
Henderson. Nevada
97 ranger
I know I saw this in here before but danged if I can find it now. My inside indicator shows second when it is in drive and neutral when in reverse, etc.. I swear I saw someplace that it is adjusted somewhere under the dash. The book says to put a 3 pound weight on the shifter and disconnect the linkage and move it through its range, then check it again. So which is it?
Confused in Vegas
Now that you said that I remember that is where I found it. Thanks again Brooklyn you have been great with all my problems.
Thanks to Brooklyn, I fixed my shifter adjustment cable in about 30 seconds. 25 seconds were spent finding it!!!
