MPVQAE
- May 30, 2020
- Section,AL
- 1999 Ford, Explorer, SOHC
99 Ford Explorer XLT 4.0 SOHC
After a lot of reading, I rebuilt my very first 5R55E. (Steels, clutches, torque converter, oil pump, OD and Intermediate servos, rebuilt valve body with trans-go shift kit, bands, O-rings, gaskets, etc.) I also know that we hate long descriptive posts. But, I don't know any other way to describe this crazy problem.
Starting up cold, place in R, back out, place in D, pullout is strong and shifts great, although the shift from 3rd to 4th seems a little short to me (I think it could hold 3rd a little longer.) But, that's not the main reason for the post. During the first 15 minutes or so, you can stop along your journey, place in Park, or Reverse, or N, and then return to Drive, pull out strong again, shifts great, no problems. Problem is, after about 15-20 minutes of driving, if you stop, remove the shifter from Drive, move to P, R or N, then return to Drive... it shutters (like it is not fully re-engaging 1st gear). Trying a few different shift scenarios, I have found the following sequence will prevent the shutter. As mentioned, after it warms up and you remove the shifter from Drive, shift to P, R, or N, then return to Drive, it will absolutely NOT shutter if you drop the shifter down below D to 2nd, or 1st (either one), then back to Drive. You can then pull out and she is perfect! As long as you stay in Drive, all is well. It's only after it warms up will it struggle with re-engaging 1st gear after being removed from Drive. But just touching 2nd or 1st on the shifter, then moving the shifter to Drive...all is well. I am wondering if there is an issue associated with the low/reverse servo. I did change the O-rings during the rebuild. Reverse seems OK and does not fell like it's slipping, although it feels a bit harsh to me going into Reverse. Could I possibly have a slight leak in the VB gasket from when I installed it? Maybe only leaks enough when the fluid is hot and thinner? I just know that being able to touch the shifter to 2nd or 1st before moving to Drive, seemingly making things work, has me a bit confused. I do have fairly high confidence in the TC and Pump. There is no shutter in either manual 1st or 2nd. I don't have a pressure gauge, but suspect that may be the next stop on this 5R55E rebuild journey, unless someone reads this and goes, "Yes, I've seen this before and know what's causing it". Or, I may just print a new user's manual for my old Explorer. Sorry for the long post.
