5R55E slipping out of first gear when warm
Salty Dalt
2001 Explorer Sport Trac
I have a 5R55E transmission that has been slipping out of first gear, almost into neutral it seems, and I have to remove my foot from the gas, and let it clunk back into gear, then it's fine. It only will do this when the transmission fluid is warm, only once, then drive with no symptoms. Or if i park somewhere for an hour, then drive again, it will do it. Making me think the solenoid(s) might be acting up with the temperature. Any help would be much appreciated.
Salty Dalt
Anybody have any help?
974X4BLACKSPORT
Location
FL
hudson
BLACK 1997 SPORT 4 BY 4
Start by getting a scanner and check for codes. ALso, make sure you are full of ATF fluid.
Salty Dalt
I had brought it in to have it looked at by Ford, they confirmed the fluid level and condition is correct. I will check for any codes, my battery completely died recently, so it might not have any yet. Will update when I know.
J 5r55e trans replacement question 2001-2005 Explorer Sport Trac 1
N 5R55E Transmission interchange? 2001-2005 Explorer Sport Trac 1
N 5r55e solenoid pack torque sequence 2001-2005 Explorer Sport Trac 1
J 05 st 4x4 5r55e transmission help 2001-2005 Explorer Sport Trac 0
S Help with 5R55E transmission issues 2001-2005 Explorer Sport Trac 2
P 5R55E Rebuild Vendor & Modifications 2001-2005 Explorer Sport Trac 3
L What year 5r55e will direct fit 02 sport Trac 2001-2005 Explorer Sport Trac 1
S what year transmission will fit in 2003 sport trac 5r55E 2001-2005 Explorer Sport Trac 0
S 2000 sport trac trans 5r55e going into 03 s/t, missing ISS sensor HELP!! 2001-2005 Explorer Sport Trac 2
firefly1246 5R55E Transmission 97-01 version vs 01-05 2001-2005 Explorer Sport Trac 2
6 5.0 /4r70W inplace of the 4.0/5R55E ? 2001-2005 Explorer Sport Trac 9
T 5R55E acts like it is in drive 2001-2005 Explorer Sport Trac 3
S Things that fall out of a 5R55E transmission and into the pan... What are these? 2001-2005 Explorer Sport Trac 4
L sport trac 5r55e to manual trans swap 2001-2005 Explorer Sport Trac 11
T 2005 sport trac XLT transmission slipping when cold 2001-2005 Explorer Sport Trac 3
K slipping transmission 2001-2005 Explorer Sport Trac 33
A 2004 Transmission Slipping Uphill 2001-2005 Explorer Sport Trac 12
T Slipping out of Park 2001-2005 Explorer Sport Trac 5
F 01 sport trans slipping or is it a misfire 2001-2005 Explorer Sport Trac 11
D tranny slipping and no brakes 2001-2005 Explorer Sport Trac 0
S Vibration while in gear (in D or R); goes away in Neutral 2001-2005 Explorer Sport Trac 0
K Tranny wont shift into 3 rd gear 2001-2005 Explorer Sport Trac 0
2 gear shift repaired but only moves between R and 3rd Gear 2001-2005 Explorer Sport Trac 3
G Rear Axle Gear oil leakage 2001-2005 Explorer Sport Trac 6
M Where to find this timing chain gear bolt 2001-2005 Explorer Sport Trac 4
B Transmission or Gear Lever Shiftier Problem --- Need Help! 2001-2005 Explorer Sport Trac 0
D Vehicle Rating Label missing, next best way to find the gear ratio? 2001-2005 Explorer Sport Trac 3
G Clutch problems/Will not shift into Gear on a 2003 ST 4x4 2001-2005 Explorer Sport Trac 3
R Gear Ratio Help 2001-2005 Explorer Sport Trac 1
B 1st gear 2001-2005 Explorer Sport Trac 0
R 01 Speedometer gear 2001-2005 Explorer Sport Trac 0
T sport trac gear swap 2001-2005 Explorer Sport Trac 7
D 03 Sport Trac Gear Shift Indicator 2001-2005 Explorer Sport Trac 6
04trac Gear question, How many spline 2001-2005 Explorer Sport Trac 9
D Gear Oil 2001-2005 Explorer Sport Trac 4
T Cb gear 2001-2005 Explorer Sport Trac 14
P Gear Oil Leak from Rear Differential 2001-2005 Explorer Sport Trac 4
M will not shift into next gear 2001-2005 Explorer Sport Trac 0
S what gear oil should i use 2001-2005 Explorer Sport Trac 1
0 What is my Gear Ratio? 2001-2005 Explorer Sport Trac 7
B Gear selector indicator 2001-2005 Explorer Sport Trac 4
S 05 Sport Trac tranny whines in 1st gear 2001-2005 Explorer Sport Trac 0
T no first gear!!! 2001-2005 Explorer Sport Trac 4
S 200 000 kms Tranny Whine in first gear 2001-2005 Explorer Sport Trac 0
F 2001 Sport trac 4x4 5spd auto Parking Gear Slips ? Why ? 2001-2005 Explorer Sport Trac 0
Similar threads
