ve7fet
- November 8, 2013
- '06 F350
Hi,
First post here, but spent the last few days running the search engine and taking a crash course in the 5R55E.
Here's the story...
'05 Sport Trac, 174,000km, runs like a top. Until the other day when the wife is backing up and hears/feels a bang. Gets out to see what she hit, nothing there, drives off.
Next day, she goes to back in to her parking spot at home, throws it in reverse, nothing there... just like neutral.
So, I then spend the next few days (mostly here), trying to figure out what has happened.
I've got the factory workshop manual, and the ATSG manual for this transmission, yes it is a 5R55E, they used them in the ST right through to the '05 production year (last production before switching to the new body style in '07).
Still shifts up through all forward gears fine.
Have manual 1st gear, but it appears to not have any engine braking.
My research points to either a bad reverse/low servo, or broken reverse band.
Did a line pressure test, all line pressures are good.
At idle we've got 220psi in reverse, so no blown reverse servo gasket or valve body gasket.
Tried the stall test in the workshop manual for reverse, fails (figured it would). Exceeded the RPM's listed in the test (>~3100), obviously because there is no apply pressure to the band/drum.
So, time to drop the pan and have a look at the reverse servo and check the band... or so I thought.
Oil's out, pan's dropped, got the cover off the reverse servo, gasket is good, but I cannot for the life of me get the servo piston out.
I can move the outer part of the plunger/piston (the aluminum part) around, so it would appear to not be wedged on the o-rings too bad, but no matter how hard I pull and wiggle with a pair of vice grips on the piston (on the raised aluminum casting), it will not come out.
Of course all the manuals, and every one else, says "remove piston", implying that it should just come right out.
Mine, not so much.
Anyone got any wise words of wisdom on how to get this piston out?
My theory right now is that the tip has mushroomed, or somehow the piston shaft has become bent, and is jammed in the upper part of the bore, preventing it from sliding out.
The only thing I can come up with is to drill and tap the aluminum plunger part of the piston, stick a slide hammer on it, and try and pull it out. Not sure what other damage this will do the upper bore, but I am running out of ideas.
Has anyone else seen this problem before, and got ideas on how to correct it?
I picked up a 5R55E and transfer case from an '01 ST for cheap, hopefully it works... but at least it is a backup and an option I can go with if I need to.
I really want to check this reverse band before I go and re and re the used one in. If it is just a piston problem (hopefully), and the band is still good, that would save a whole lot of headache.
I look forward to your wisdom.
Thanks!
Lee
Here's the story...
Mine, not so much.
Thanks!
Lee
