Mike120
- January 4, 2013
- Virginia
- '99 Ford Explorer XLT 4x4
Im having some trouble with my 5r55e swap, ive pulled the old trans and swapped in the new one already but something is wrong. Now when i start it, it will only start in neutral and wont shift into gear at all. Ive checked the trans wiring harness thoroughly(i pulled it out, checked wires visually and with a voltmeter and retaped it up). One thing ive noticed is when i put it in drive the rpms change as you would expect but still wont move anywhere, also strange is that when in drive, when i press on the gas the rpms stay high for several seconds even after i let off the gas.
I also pulled several codes with a scanner:
p0743 p0750 p0760 p0765 and also po174(i think the last code has to do with the fact that i had to cut off a cat to get the trans out and currently the patch i put on it isnt great) Also i tried erasing the codes when i reinstalled the harnes but still no joy
Heres the specifics:
-99 ford explorer 4.0 SOHC
-The replacement trans is from a salvage yard(i bought it through pickapart.com)
-The new trans is supposed to be from the exact year and model ex but i cant be 100% sure bc my trans sticker has worn off but both look exactly the same, no extra plugs or anything at least.
Please keep in my this the most difficult thing ive ever attempted with a car and while i am mechanically inclined i am only 19 and i may need you to spell things out to me lol
