5R55E transmission is taking off in 3rd gear. | Ford Explorer - Ford Ranger Forums - Serious Explorations
roberson30
Brandon, MS
1998 explorer 4x4
Having trouble with my 1998 explorer 4x4 It seems that the trans is taking off in 3rd gear and shifting up but when I stop it is not shifting back down to 1st or 2nd. The transfer case is working properly but the main trans is where I believe the problem is. I did change the range selector motor on the transfer case, could there be a wire that I misplaced. The plug was a real pain to change. Where could I find a wiring diagram to check my work. Thanks Gene Roberson
Welcome to this forum! I've renamed, and moved your thread to the transmission section. Do you have a flashing overdrive light? Did you scan the PCM for stored trouble codes?
Trans problem stuck in 3rd
Thanks for your reply, Yes the overdrive light is blinking and when I scanned the codes it showed multiple codes as if I had a catastropic failure, Everthing from Torque converter to 1-2 shift 2-3 shift 3-4 shift and all kinds of crazy stuff. I feel like I have abigger problem that just changing filter and fluid will fix. Have 164,000 miles on explorer.
Multiple codes might indicate a problem with the internal wiring harness or the connnection of the external bulkhead connector.
Trans shift
Thanks, I will disconnect and clean the contacts in the harness, Never thought of that, The car is on an island in Exuma, Bahamas and there is not a lot of technical help here, so you have to figure things out. Thanks again Gene
