Kavlainc
- May 3, 2010
- '06 4.0 XLT
I changed my radiator and about a pint of ATF came out. I got the instructions online on how to do a ATF level check. Got my adapter for the plug and the pump, so all the tools are handy. Got the car running, shifted through all the gears and unscrewed the drain plug. Another pint dripped out of the drain hole until I screwed the plug back in.
I'm getting confused here, is my level ok? If not how in the world am I suppose to refill the fluid if it's always dripping/leaking out? I'm just baffled by the process, I did not think that much fluid will be leaking/dripping out of the drain hole.
Thanks
Thanks
