5r55s relearn.
Littleant
Location
Vermont
Orleans
2010 Mountaineer 4.0
Do not have and issue but I saw a video on this. by @fordtechmakuloco.com and disconnecting the battery and and connecting pos and neg terminal together is not the proper way to do it. fordtechmakuloco stated that a meter that reads trans must be used to delete the previous sertings. True or false. Trans guys @JK080
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
donalds
Location
Stem
Nc
1999 ford explorer sohc
Disconnect battery and connect positive and negative together for 10 min
or use a ford ids scan tool $$$
Or forscan with a elm adaptor
It will work for you so far it worked for everyone else good luck put the @ symbol before the name for example
@JK080
Littleant
Location
Vermont
Orleans
Thanks for the input donalds.
JK080
Transmission Moderator
Staff member
Moderator
North Ga
05 F250 6.0
Funny I never got the tag...
Anyways, I have only reset shift adapts with a scan tool, but I do know that having the battery disconnected (on some vehicles) for a while will reset the adapts as well as donalds said.
Littleant
Location
Vermont
Orleans
Thank you Donalds and JK080
donalds
Location
Stem
Nc
No problem I enjoy helping immensely
Give help get help repeat:)
N 5R55S always in reverse Transmissions & Transfer Cases 3
G 5r55s reverse servo apply lever and rod Transmissions & Transfer Cases 4
S 5r55s whining noise Transmissions & Transfer Cases 3
S 5R55S P0775 issue - lesson learned, damage done? Transmissions & Transfer Cases 6
I Weight of a 5R55S? Transmissions & Transfer Cases 6
R P0741....5r55s Transmissions & Transfer Cases 0
C Solved New 5R55S. The transmission slips. Transmissions & Transfer Cases 6
K 5R55S to rebuild or not Transmissions & Transfer Cases 15
A 5R55S drives forward just fine / Reverse only works if I do not press the gas Transmissions & Transfer Cases 17
D 2003 5r55s with 247k is tired... Transmissions & Transfer Cases 7
J 5R55S Servo Bore Fix Fail After Classic Symptoms Transmissions & Transfer Cases 6
domct203 Solved 5R55S servo cover popped off. Transmissions & Transfer Cases 52
J Hi All my first time dose rebuild kit for 5r55w fit 5r55s Transmissions & Transfer Cases 1
P 2006 5r55s trans swap Transmissions & Transfer Cases 1
B 5R55S Solenoid Pack??? Transmissions & Transfer Cases 2
J 5R55S Total fluid change-how to do? Transmissions & Transfer Cases 1
W 5r55s forward planet bearing help Transmissions & Transfer Cases 11
B Solved 5R55S adjustment tools. Transmissions & Transfer Cases 14
S 5R55S slow engagement after fluid and filter service Transmissions & Transfer Cases 20
K 5R55w to 5R55S swap Transmissions & Transfer Cases 6
D 5R55S Shift Reprogram Kit Question Transmissions & Transfer Cases 3
L 5r55s Double engagement or harsh reverse Transmissions & Transfer Cases 2
J Has someone swapped a 5r55w to a 5r55s? Transmissions & Transfer Cases 7
O [5R55S] No Reverse | Can't Take Off In 'D' Transmissions & Transfer Cases 9
A 5r55s/w no forward gears copper in fluid Transmissions & Transfer Cases 18
E 2004 Ford Explorer 5R55S shifting problems Transmissions & Transfer Cases 1
D Rebuilt 5R55S, please help me DECODE what the repair shop did. Transmissions & Transfer Cases 3
R 5r55s fluid Transmissions & Transfer Cases 0
E 2005 Explorer - 5R55S - Overdrive Planet sprag bearing fail Transmissions & Transfer Cases 1
D 5R55S o/d light blinking light Transmissions & Transfer Cases 2
R New member 5R55S replace the 5R55W? Transmissions & Transfer Cases 5
C Can anybody recommend a good transmission rebuild kit for the 5R55S? Transmissions & Transfer Cases 4
4pointslow Transmission Shift Flare/Slipping on 2-3 shift 5R55S 2004 Explorer Transmissions & Transfer Cases 19
D Midwest shops that can bore and sleeve the servos on 5R55S? Transmissions & Transfer Cases 1
08EddieCA New Front Pump 5R55S = must the trans be vertical to install the new pump Transmissions & Transfer Cases 5
D advice needed re. 5R55S parts swap . . . Transmissions & Transfer Cases 9
J 2005 Explorer 5R55S Loss of 2nd Gear Transmissions & Transfer Cases 8
H 5R55S 05 explorer wouldn't start. Transmissions & Transfer Cases 3
M 05 expl 5r55s diagnostics and repair. a self educating journey. Transmissions & Transfer Cases 20
D 5R55S Rebuild. Is the Ford factory kit adequate? Transmissions & Transfer Cases 2
08EddieCA Having reman 5R55s installed. Radiator, lines, cooler Transmissions & Transfer Cases 2
J 5r55s OD button Transmissions & Transfer Cases 13
G 5R55S Delayed Engagement Transmissions & Transfer Cases 5
G Swapped 5R55S for 5R55W, should I swap pcm as well? Transmissions & Transfer Cases 7
C 03 5r55s in an 07? Transmissions & Transfer Cases 2
4pointslow Filling the 5R55S Transmissions & Transfer Cases 8
H How many shifts from a 5R55S? Transmissions & Transfer Cases 3
4pointslow 5R55S pump replacement Transmissions & Transfer Cases 8
S broken od servo cover,5r55s 03 explorer Transmissions & Transfer Cases 1
T New 5r55s problem Transmissions & Transfer Cases 2
Similar threads
