5r55s reverse servo apply lever and rod
Greg24
Washington, MI
2004 Ford Explorer XLT
Hello all. New to the forum. I am currently rebuilding a 5r55s and need to swap cases due to OD servo blowing a chunk of the case out the side. I have disassembled the enter tranny but cannot figure out how to remove the reverse band strut lever and rod. I have not found any videos or instructions on how to do so. Has anyone here done this before?
Greg
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
transman304
Morgantown WV
2001 Honda Accord
Welcome to the forum,
transman304
Morgantown WV
2001 Honda Accord
Your welcome, most of the time they will fall out. But have had some that needed vice grips on to remove. Good luck.
Also a tip that can save you some problems when being reassembled.
Brad.
Greg24
Washington, MI
Brad.
Thanks again Brad. It fought me to the end but I finally got it out. Thanks for the extra tips too!! Greg
R 5R55S reverse servo has a pin hole in it Transmissions & Transfer Cases 14
R 5r55s reverse servo broken screen? Transmissions & Transfer Cases 3
N 5R55S always in reverse Transmissions & Transfer Cases 3
A 5R55S drives forward just fine / Reverse only works if I do not press the gas Transmissions & Transfer Cases 17
L 5r55s Double engagement or harsh reverse Transmissions & Transfer Cases 2
O [5R55S] No Reverse | Can't Take Off In 'D' Transmissions & Transfer Cases 9
E 5R55S - Reverse doesn't want to engage Transmissions & Transfer Cases 0
W 5R55S Transmission no reverse, 4th, or 5th Transmissions & Transfer Cases 0
T 5R55S harsh shifting; bump engaging reverse; Transmissions & Transfer Cases 26
G Hard Reverse 5R55S Transmissions & Transfer Cases 9
jrford 5r55s Code P0733, no reverse gear, OD Flashing, Check Trans light- at dealer now Transmissions & Transfer Cases 2
G Please Help 5r55s, 04 Ex, reverse SLAM BAD! Transmissions & Transfer Cases 6
S 5r55s whining noise Transmissions & Transfer Cases 3
S 5R55S P0775 issue - lesson learned, damage done? Transmissions & Transfer Cases 6
I Weight of a 5R55S? Transmissions & Transfer Cases 6
R P0741....5r55s Transmissions & Transfer Cases 0
L 5r55s relearn. Transmissions & Transfer Cases 5
C Solved New 5R55S. The transmission slips. Transmissions & Transfer Cases 6
K 5R55S to rebuild or not Transmissions & Transfer Cases 15
D 2003 5r55s with 247k is tired... Transmissions & Transfer Cases 7
J 5R55S Servo Bore Fix Fail After Classic Symptoms Transmissions & Transfer Cases 6
domct203 Solved 5R55S servo cover popped off. Transmissions & Transfer Cases 52
J Hi All my first time dose rebuild kit for 5r55w fit 5r55s Transmissions & Transfer Cases 1
P 2006 5r55s trans swap Transmissions & Transfer Cases 1
B 5R55S Solenoid Pack??? Transmissions & Transfer Cases 2
J 5R55S Total fluid change-how to do? Transmissions & Transfer Cases 1
W 5r55s forward planet bearing help Transmissions & Transfer Cases 11
B Solved 5R55S adjustment tools. Transmissions & Transfer Cases 14
S 5R55S slow engagement after fluid and filter service Transmissions & Transfer Cases 20
K 5R55w to 5R55S swap Transmissions & Transfer Cases 6
D 5R55S Shift Reprogram Kit Question Transmissions & Transfer Cases 3
J Has someone swapped a 5r55w to a 5r55s? Transmissions & Transfer Cases 7
A 5r55s/w no forward gears copper in fluid Transmissions & Transfer Cases 18
E 2004 Ford Explorer 5R55S shifting problems Transmissions & Transfer Cases 1
D Rebuilt 5R55S, please help me DECODE what the repair shop did. Transmissions & Transfer Cases 3
R 5r55s fluid Transmissions & Transfer Cases 0
E 2005 Explorer - 5R55S - Overdrive Planet sprag bearing fail Transmissions & Transfer Cases 1
D 5R55S o/d light blinking light Transmissions & Transfer Cases 2
R New member 5R55S replace the 5R55W? Transmissions & Transfer Cases 5
C Can anybody recommend a good transmission rebuild kit for the 5R55S? Transmissions & Transfer Cases 4
4pointslow Transmission Shift Flare/Slipping on 2-3 shift 5R55S 2004 Explorer Transmissions & Transfer Cases 19
D Midwest shops that can bore and sleeve the servos on 5R55S? Transmissions & Transfer Cases 1
08EddieCA New Front Pump 5R55S = must the trans be vertical to install the new pump Transmissions & Transfer Cases 5
D advice needed re. 5R55S parts swap . . . Transmissions & Transfer Cases 9
J 2005 Explorer 5R55S Loss of 2nd Gear Transmissions & Transfer Cases 8
H 5R55S 05 explorer wouldn't start. Transmissions & Transfer Cases 3
M 05 expl 5r55s diagnostics and repair. a self educating journey. Transmissions & Transfer Cases 20
D 5R55S Rebuild. Is the Ford factory kit adequate? Transmissions & Transfer Cases 2
08EddieCA Having reman 5R55s installed. Radiator, lines, cooler Transmissions & Transfer Cases 2
J 5r55s OD button Transmissions & Transfer Cases 13
Similar threads
