smitchell
- June 2, 2018
- Location
- San Angelo Texas
- San Angelo, Texas
- 2004 Explorer 4.0L/5R55S
The transmission had no problems before servicing. After servicing, it is slow to engage after coming to a stop or coasting down to a lower gear, there is a delay engaging. After stopping it needs to hit 1800 rpm to engage and does so harder than normal. You can bring the rpms up slowly to about 1200 rpm and after a longer delay it will engage. When pressing the accelerator, the rpms do not rise immediately. It acts like the computer controls the rpm increase (this might be normal, but if really do not know). After stopping, if shifted to park or neutral and back into gear it engages normally. So this problem only occurs after moving forward then stopping, or coasting with at least one downshift.
2004 Explorer, V6, 5R55S, 5-speed with 130,000 miles and no history (no trailer hitch). Vehicle had one previous owner, is in excellent condition and had a recent oil change sticker in windshield when I purchased it. It did not appear abused when I purchased it. I have had it for 9 months and it has driven prefect in that time. I decided to service the transmission as best practice. The transmission has operated normally before the service. New fluid: Valvoline Max Life, Full Synthetic with Ford filter.
Changed fluid, filter, and cleaned the pan and magnet. Fluid was somewhat discolored, no metal debris in pan, and the magnet was saturated. Old o-rings came out with the old filter and installed the new filter with supplied o-rings. Checked the fluid level after bring the transmission up to operating temperature. It poured some, then slowed to a drip, put the Torx plug in.
After servicing and before moving the vehicle, shifted through the gear range and each gear engaged. It backed out normally, went forward normally. Reached the end of the yard, stopped for traffic, then pressed accelerator and there was about a five second delay engaging with a harder than normal engagement. It does not do this in reverse. It only does it after the vehicle is in motion and then stopped in drive or any forward gear with 3 to 6 second delay and a harsher engagement. If the accelerator is applied a little while stopping, the transmission remains engaged and moves forward with no delay. Occasionally it does not do this, but does it more than not.
This morning, I checked for leaks and none. I then added a half pint of fluid. Pulled the Torx plug, it dripped and accumulated about a half pint in the pan. I added another pint and put the plug in quickly. The additional fluid made no difference. I then drove out of town 90 miles with no stops. I then wait two hours and drove around the neighborhood stopping and going. There seemed to be some improvement at first and I almost thought it had cleared up, but the problem is back and is steady in the delayed engagement.
I am mechanically inclined, have a working knowledge of automatic transmissions and have never gone past a normal service. I can handle troubleshooting and repairs. Suggestions please?
S Mitchell
S Mitchell
