jah81592
- June 12, 2005
- Corner, AL
- 2001 Explorer Sport
5R55S swap/conversion
This thread is going to be in detail about what it takes to swap a 5R55S into your Explorer. As of today there is a standalone unit available (which I will be a dealer for) to control this complex tranny. I have previously kicked around swapping in a 700R4,4L60E, custom building the 5R55e (which physically doesn't have the major hard parts available), but I just couldn't bring myself to a GM trans and the 5R55E just will be a toss up with staying together in the future plans for my vehicle. Whatever I did had to have electronic controls so obviously the 7ooR4 swap is out as well. So my next conclusion was why not swap in a 5R55s which is readily available and is able to withstand the rigors I will be putting on it. This tranny is designed with the v-8 in mind so placing it in duty with a Turbocharged v-6 should not pose any problems with longevity. As well as that this tranny is starting to gain steam with the aftermarket. I have successfully used the 5R55E which is only rated at about 250HP and probably around 300lb.ft torque and I feel I have exceeded what this tranny can supply me. So as of now my best setup is going to be this 5R55S trans swap.
I will take pictures and highlight anything you will need to do to keep the trans swap simple and keep it Ford. I know there will be some setup pains and I will probably change things in the future so this thread will evolve. I believe this will be a good alternative for the 2wd street guy on these forums looking to keeping the electronic controls and the 5speed auto.
