The EPC solenoid regulates the pressure with the command of the PCM. The PCM could request higher or lower pressure depending upon the input of various sensors.
so is this to say that if the EPC circut failed, that the main circut would fail as well?
is each circut supplied individually by the pump.
I actually think I remember the frankentranny thread to cover this in part - I'll go re-read.
It would be interesting to have a flow chart of the passageways to each shift cycle and function.
I read a thread on syncro vs non-syncro shifts that either you or glacier posted - I never thought about shift cycles until I read that.
anyway - looks like the main port is the best option for the pressure guage.
just because I am curious about temp also(and sensors are only $10) I am going to install sensors at the output & input cooler lines as well as the pan.
I will simply replace the 1/8" plug that was used for checking fluid level in the pan bottom for the third sensor.
curiosity killed the cat, but not the trans.
OK, now onto the speed sensor issue......
My buddy at ford called me this morning and said that the part #'s when ordering are all the same, so the stamped # must be a lot s/n or something.
He also said from his experience that when these sensors fail, they usually go OL(open line).
