Russ in CT
- November 11, 2002
- Milford, CT
- '99 XLT
I just got an '02 Ex, SOHC V6 with 5R55W (no dipstick). Its got 107K on it, so its technically not due for a tranny fluid change for another ~40K miles, but I think even 100K is too long. So I want to change the fluid. But if I just drop the pan, replace the filter, then refill, I'm leaving a lot of old fluid behind. Is there a way to completely flush it?
What if I drop the pan and change the filter (clean pan, clean magnet, etc), prefill approximate level, then use the tranny cooler lines to flush it? Hook up intake line to fresh fluid, output line to bucket, and run engine until clean fluid comes out. Then let it drain from the 'fill plug' at the bottom of the pan until its at the proper level (or add if its low).
Will this work? What is wrong with this plan?
