5R55W Issues..... 2003 XLT/NBX 4.0 SOHC.
Swinson1974
Lebanon, PA
1996 4.0 Explorer XLT
I changed the trans filter today and the fluid. It was a pain in the butt. It fills from the bottom. It calls for 4 QTs and fill with 5th until it runs back out of the whole while the truck is idling at normal temp.
I removed a little less than a gallon by letting the drain run then dropping the whole pan and poured it into fluid pan. I figured it must have been low.
I then added two qts to the pan so I'd have less to pump into it afterward (yes I cleaned out everything first.) and then replaced the filter and bolted it back up. I started the car and let it heat to normal temp.
I then pumped two more qts in and removed the hose, nothing was running out. I added the 5th qt and once the fluid was running out I recapped it once the drip slowed down.
PROBLEM... Now when I drive it, it revs in reverse and drive and then catches the gear and goes. It feels like a neutral drop we used to do when we were young and dumb. Once it's driving it's fine and does all it should. I stop at a light or a stop sign and sometimes it acts normal, sometimes it does the neutral drop. When it does the neutral drop it's only after I feel something disengage while I have the brake pedal pressed. I actually felt it disengage, then reengage, then disengage, then reengage once and it moved normal when I hit the gas.
I'm lost. It almost feels like maybe not enough fluid but I don't want to add more and over fill it.
I used (4) Lucas Auto trans fluid and (1) qt of Lucas trans anti slip.
Can anyone offer any help or ideas please?
Cowens726
Salem, OR
2005 XLT
Was your rig level when you did this? I ask because when I did this for my 2005 a couple years ago and the directions I followed specifically advised that the rig/transmission was level. My driveway has a decent slope so I ran the back tires up ramps until the tranny oil pan was level. I would think if the transmission oil pan was tilted back towards the drain plug, you would not be able to get the correct amount of oil in the trans. I don't recall how many qts. of oil I added but I followed the same procedure as you and haven't had an issue since. Actually planning on doing it again next oil change just to be on the safe side 150,000 miles and plan on many more. Not sure about the oil that you used I just used straight up Mercon V or whatever it is that is recommended but it definitely sounds like you are low on oil.
Swinson1974
Lebanon, PA
I was originally on front ramps to get underneath easy, but I took it off the ramps when I started it to let it run to normal temp then check. I knew that would be be an issue just like you said. I've learned the hardway in the past on my older expos. I'm not positive if anyone ever changed it before, it's at 180k. There was a cool reusable gasket on it, so it's probably (thankfully) something that has been done before. I've gotten them at 150k and they haven't even changed the spark plugs. It was commented on the Facebook page for Serious Explorations where I posted also that I may not have put the tranny through the motions so all the fluid was up in the transmission. I'm picking up another QT this morning to check it again, I drove it for a half hour last night in all gears so hoping it fixes it. It reminded me of driving one of my 1st gens with low fluid, I just wanted to check before I added more and ruined it. TY for the response :)
02ex4x4
I'm willing to bet it will clear up I do run the lucus additives but I mix it with the rest of the atf I will be adding to thin it out . If you just poured it in you sucked up straight lucus and the valves in the valve body are sticky. Until it thins itself out it will more than likely have some issues. Check fluid again and drive it let it engage before you hit the gas and keep working it . I bet it will clear up.
Swinson1974
Lebanon, PA
Yea, I got another quart today and when I went to add more (with it running at temp) the fluid was running out frothy. I'm pretty sure my issue was overfill and not underfill. So now I have to most likely take it to a shop and have them totally change all the fluid, not just the 4-5 qts in the pan. From everything I have read, I may have ruined the fluid and when it is overfilled, it delays the gear shifting and makes it shift hard which was the initial problem. Reverse isn't delayed anymore, but drive still is. Just to be sure tomorrow morning I'm going recheck it because I went and drove it 2-3 miles to make sure the fluid was up in the trans where it needed to be. TY for the response.
Drewmcg
Location
Michigan
Ann Arbor, MI
2010 XLT 4WD
2002 XLS 2WD
I really prefer Mercon V (Motorcraft) for these trans's . . . .
0 5r55w issues Stock 2002 - 2005 Explorers 8
M 5R55W Performance Issues Stock 2002 - 2005 Explorers 4
M 5R55W trans issues... Stock 2002 - 2005 Explorers 6
T 5R55W may or may not go in gear on start up and stops pulling after coasting randomly Stock 2002 - 2005 Explorers 6
S No 3rd Gear on 5R55W - will rev to redline and not shift Stock 2002 - 2005 Explorers 1
M 2002 Explorer 5R55W Trans Won't Go Into Any Gear, No Codes Stock 2002 - 2005 Explorers 1
L 5r55w transmission trouble Stock 2002 - 2005 Explorers 1
L 2002 explorer: 5r55w intermediate servocap blows out AGAIN ! Stock 2002 - 2005 Explorers 2
D 5r55w front pump clearance Stock 2002 - 2005 Explorers 1
B 5r55w no movement Stock 2002 - 2005 Explorers 2
L 02 Explorer 5R55W intermediate servo install problem Stock 2002 - 2005 Explorers 8
B 5R55W TORQUE CONVERTER Stock 2002 - 2005 Explorers 3
W 03 xlt 4.0 4wd 5r55w code p0735 p0775 flashing OD HELLLLLLLP! Stock 2002 - 2005 Explorers 18
R 5r55s vs 5r55w Stock 2002 - 2005 Explorers 2
S 5r55w or 5r55s tranny... Stock 2002 - 2005 Explorers 2
W 03 Explorer 4wd 5r55w going into neutral while in drive or reverse Stock 2002 - 2005 Explorers 55
B 2003 Explorer 5r55w transmission problems Stock 2002 - 2005 Explorers 2
3 5R55S swap to 5R55W Stock 2002 - 2005 Explorers 1
L Rebuilt 5R55W with Remanufactured Torque Converter Stock 2002 - 2005 Explorers 7
O 5R55W fault Explorer 2002 edie bauer 2x2 Stock 2002 - 2005 Explorers 2
0 5r55w alignment and assembly pdf Stock 2002 - 2005 Explorers 0
0 Hello Another 5R55W conundrum. Any trans gurus? Stock 2002 - 2005 Explorers 17
D Quick Question regarding OD band/Servo issue in 5R55W tranny Stock 2002 - 2005 Explorers 13
N 5r55w 02 Explorer XLT Stock 2002 - 2005 Explorers 3
G 5r55w servo fix only OD and intermediate new Stock 2002 - 2005 Explorers 0
A 5R55W doesn't engage when going from P to D and P to R Stock 2002 - 2005 Explorers 24
M 5r55w trans Stock 2002 - 2005 Explorers 0
G 5R55W - intermittent no movement Stock 2002 - 2005 Explorers 10
0 5r55w tcc/trans advice Stock 2002 - 2005 Explorers 9
J 5R55W trans oil change Stock 2002 - 2005 Explorers 3
R 5r55w Transmission Won't Shift Stock 2002 - 2005 Explorers 2
R Remanufactured 5r55s/5r55w transmission - Any Sugestions Stock 2002 - 2005 Explorers 5
H 5R55W OD band replacement Stock 2002 - 2005 Explorers 1
H 5R55W transmission fluid flush idea Stock 2002 - 2005 Explorers 4
H 5R55W Help! Stock 2002 - 2005 Explorers 6
H 5R55W O/D band adjustment concern Stock 2002 - 2005 Explorers 1
H 5R55W bonded separator plate reusable? Stock 2002 - 2005 Explorers 2
D 5R55W trans fluid question Stock 2002 - 2005 Explorers 11
R Rebuilt 5r55w lost drive & reverse Stock 2002 - 2005 Explorers 2
M 5r55w woes Stock 2002 - 2005 Explorers 16
J 5r55w question Stock 2002 - 2005 Explorers 1
R 02 Explorer 5R55W Rebuild Snafu Stock 2002 - 2005 Explorers 2
M 5r55w 4x2 transmission interchange Stock 2002 - 2005 Explorers 0
S Need a complete pump assembly for 5r55w Stock 2002 - 2005 Explorers 0
P 5r55w question Stock 2002 - 2005 Explorers 3
R 5R55W trans fluid direction Stock 2002 - 2005 Explorers 3
P 5R55W Broke OD Servo Shaft Stock 2002 - 2005 Explorers 2
G trouble shifting out of park after fluid change 5r55w tranny Stock 2002 - 2005 Explorers 1
J 5r55w Stock 2002 - 2005 Explorers 1
T 5r55w slips 2nd and 3rd harsh shift Stock 2002 - 2005 Explorers 7
Similar threads
