Russ in CT
- November 11, 2002
- Milford, CT
- '99 XLT
2002 EB 4.0 4x4 ~115K miles. I bought the truck with ~107K miles, and noticed a 2-3 flare. So while I waited to get around to fixing it, I really babied it (also had a rattlin' timing chain, another reason I was babying it).
Finally did the solenoid pack (and the timing chain tensioners), along with a complete fluid change (engine assisted flush), and now that I'm driving more 'briskly', I've noticed some other issues (meanwhile the 2-3 flare is indeed gone). What is happening now (could have been all along, no reason to think these symptoms are new) is that under load (accelerating up hill from a stop, even if its only a slight grade) in low gears (1st & 2nd), it does this 'bumping' action. Its like the tranny is grabbing or something, almost feels like mini-shifts are going on. Its not slipping, no rpm increase or power loss, just a bump in the seat of the pants. It'll do it like 3 or 4 times in each gear (just 1st & 2nd).
Its only noticed under some load (even just a slight grade), and if you really baby it it doesn't occur.
The other 'issue' is the 1-2 shift is delayed when under heavier accel. Not noticed just driving around, but if you are more than say, half-throttle, it tachs up and stays there way longer than it should before it shifts into 2nd. The shift itself seems OK, its just late.
I haven't done a band adjustment yet (gotta pick up an inch-pound torque wrench first), but other than that, what can I do to stave-off the inevitable full tranny rebuild that will eventually be required? (I'll be racking up lots of miles on this rig)
