Another One
It looks like this thread is old and I'm not sure anyone will read this, but I am posting to share the fact that I am having shift issues between 2 and 3 as well - plus I need to vent. This has been going on for over a year and it hasn't got worse, but I am going to replace the sol pack this weekend. The wife and I have just got used to making it work by letting off the gas at 3000 RPM. I too have the ODB code that says bad solenoid. I finally have the time to dive in and I really appreciate this post to know what I am getting into.
This issue started with the engine light coming on and the slip after 2nd gear. If I'm turning a corner and can not come to a complete stop, it seems like the tranny gets confused and then will start clunking into 3rd and the OD light will start blinking rapidly. When this happens, I have to change driving style and start letting the gas off at 2500 RPM to minimize the "clunk" into 3rd. After turning the engine off and restarting, the OD light is out and we go back to letting the gas off at 3000. It seems so many people have had this problem there should have been a recall or a free fix. I know that 176K millage is out of warranty, but still...
I also have seen this 'O2 EB just start falling apart - it seems. All the interior door trim pieces have started coming out, the back hatch has a crack down the center, the key won;t come out of the ignition, the stereo volume only turns UP with the knob-I have to use the control on the steering wheel to turn it down, I replaced all 4 wheel bearings (my 92 still has originals), there is a whine in the rear differential. ug! I like the truck so I keep it - cheaper than replacing the whole vehicle, but FORD really seemed to lose pride in workmanship on this one.
Well I'll post to update on how this project goes. I am hoping I don;t need to flash anything or get it all back together and have the same problem.
Thanks again!
