5R55W Solenoid Pack ? re Torque Conv. | Ford Explorer Forums - Serious Explorations
buzman78
Virginia
2002 Mountaineer 4.6 AWD
Hello all, I still have no answer regarding the hard downshift question re my 02 Mountaineer. One suggestion I received was to change the fluid and replace the solenoid pack.
Don't really want to buy a new solenoid pack at close to $300 unless I'm pretty sure it will fix the problem. This leads me to my question:
Does the solenoid pack control lock-up of the torque converter? If not what does? I am thinking lock-up may be the hard jolt on downshift as in my link below.
Thanks in advance.
Link to the description of my problem in stock 3rd Gen-
http://www.explorerforum.com/forums/...d.php?t=257541
It does lock the converter and it happens around 45 mph you should only see a drop in rpms. If you let off gas or apply brake it should unlock
Thanks in advance.
Upon lock-up, assuming normal conditions, the TCC (Torque Converter Clutch) engages, or locks, very gently, sometimes unknown to the occupants of the vehicle. Upon throttle demand, like starting to climb a hill or acceleration called for, the TCC disengages, or unlocks, with a surge felt in the vehicle as the engine speeds up. It feels much like a downshift. Watching the tachometer while using the gas pedal can reveal whether the TCC is functioning properly, or at all.
