lief
- December 18, 2014
- Cary, NC
- 2002 ford
Hi All, new to the site ....
Symtoms: When I put it into 1st or reverse, trans does not engage.
If I increase the RPMs to 1000 shifting works
Please help if you know this issue!
Neighbors SUV issue:
2002 explorer XLS 4.0L 4door 2WD
automatic 5r55w, part number 1L2p 7000 AE
Installed valve body: no help, symptoms didn't change
all stock with 110,000 miles
Changed trans oil: No help, symptoms same
I have seen the A4LD trans has a FAQ that seems to address this/similar issue
The FAQ states the following:
What is the issue and can it be fixed the same way at the A4LD?
A4LD COMMON PROBLEMS
Q1. I have a delayed engagement into reverse (sometimes also into drive). Why is this and how can I fix it?
A. In the A4LD the reverse band is used to engage both reverse and 1st gear. The servo that engages it has a seal prone to leakage, and it also has a rather large volume that needs to be filled and pressurized.
More often that not this is the culprit. Sometimes a leaky seal, sometimes a slow fill because of VB issues. About 50% of the people will find a fix in replacing the seals on the low/reverse servo with either a "double lip" upgrade, or a "D ring" seal kit. Both are cheap (under $5) but you have to drop the pan and valve body to get to it.
Good news? If you can live with it, it isn't doing any harm, just be patient before you goose it.
