Rijalo
- April 2, 2016
- Maine
- 02 Ford Explorer XLT
Hi so I'm having some trouble figuring out my transmission in my 02 4.0L XLT. It drove fine, I got home and parked it and the next morning i went to drive it and it wouldn't shift into reverse or 3rd. I got inside of the transmission and found that the filter was totally black and the fluid was real dark and burned out. I tested the solenoid pack and everything was within range besides the temperature solenoid. I had the multimeter on the 200 range for everything besides the temp solenoid at which point I switched the meter to 200k. I've read that it should read from 16k to 37k ohms but the reading was 48-51 ohms. I may not be reading the meter correctly but whether it really was 48-51 ohms or 48k-51k ohms either reading is out of range. I'm wondering if just the temp solenoid could cause this or if the faulty solenoid may have overheated the transmission destroying some mechanical component, which may also explain the burned out fluid and black filter? I should also mention that I've checked for trouble codes and there aren't any. No overdrive light flashing, it just seems like it's trying to go into gear but it can't. Does anyone know of a test i could try on the solenoid pack on a mechanical level? I'm totally stumped as to how something like this happens overnight with no warning signs or previous problems. Any help would be greatly appreciated!!!
