5R55W with no gears. | Ford Explorer Forums - Serious Explorations
vetman670
I have a 2002 08/01 ford explorer 4.0L 4x4 with the 5r55w trans. Today I noticed the OD light start blinking and now the vehicle won't move in forward or reverse. The diagnostic code is P0745 which is the pressure solenoid block. Will that stop the trans from working completly?
Welcome to this forum! I've moved your thread into the transmissions section. The solenoid block, and servo bores tend to act up around 60K miles. Make sure that you order the correct block. Check the internal wiring harness when everything is open. Make sure that you order the correct block. Check the internal wiring harness when everything is open.
