01slvrsprt
- April 4, 2008
- South Burbs of Chicago
- '01 Sport
OK, I want to start by thanking everyone that has helped me out with the the planning of this project.....
http://www.explorerforum.com/forums/showthread.php?t=212434
Everyone in that thread was a big help. Thanks again.
I also have to thank my 2 friends Mike and Josh for helping me with the lift, I couldnt have done it without you.
So here is what the plan was:
Starting w/bone stock 2001 Ford Explorer Sport add 3" lift kit, PA70023. Replace the stock shackles w/WAR-153 and give the front alittle TT, 1.5" to match the lift from the schackles. Then throw on some Dick Cepek DC-1 w/some BF Goodrich Mud Terrain 33x12.5x15 treads. I also did alittle customizing to the paint scheme which you'll find out in the finished pictures, think of it as alittle suprise
I had to do a few other things while it was in the air, change upper control arm and ball joint, lower ball joint, change the trans filter and gasket and I figured Id change the oil while I was at it.
The first pic is how she started out.
The first thing I did was remove all the ground effects, ALL of them. Now why would I do that?
