6 or 8 bolt flywheel?
cthudak
seattle wa
97 XLT
Hi,
I have a 1997 Ranger XLT 5 spd ...Does any one know a way (short of removing the transmission) to know which size flywheel I have. It appears they changed over to a 8 bolt flywheel sometime in 97?
Thanks in advance for the help..
DPDISXR4Ti
New York
2005 Mountaineer
Bumping this old post as I have the same question and I see this one never got an answer. Even the thorough article on the 4L from Automotive Rebuilder seems to miss the reality that there was NOT a clear switch-over to the 8-bolt crank starting in model year 1997. In fact, there seem to be plenty of reports from the field indicating that early and mid-97 vehicles still got the 6-bolt crank.
So again I would echo the question.... Is there any way to ID an engine with the 8-bolt crank when access to the back of the engine is blocked (i.e. there's a transmission in the way)?
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
I want to say the miss information you are finding might pertain to the 4.0 sohc having 8 bolts (started in 97) where the 4.0 ohv had 6 bolts until 98 when they changed the heads. You should be able to find pictures on here of the difference between 95TM and 98TM heads.
I haven't seen a 97 ohv with an 8 bolt crank but it's possible I'd assume in late 97 or if an engine swap has been done.
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
@DPDISXR4Ti what is it you’re trying to do? Find a replacement flywheel in the junkyard?
410Fortune
ICE Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
why? So you are looking for a 95-97 OHV.... they are getting harder to find in running condition
The last year of the OHV was 2000
from 98-00 they had the 8 bolt crankshaft
in 98 the OHV received the 8 bolt crank and flexplate/flywheel because the new SOHC engine and OHV share the same flywheel/flexplate and transmission
You can easily adapt an 8 bolt crank engine into your truck, just buy the correct flywheel
The really nice part about this is the 8 bolt flywheel accepts a larger clutch, larger clutch = better grip.
I routinely install 8 bolt crank OHV's into the older trucks using either the 8 bolt flexplate for auto's or the 8 bolt flywheel for sticks and then use a 2004 Ranger edge clutch
DPDISXR4Ti
New York
2005 Mountaineer
I bet none of them went into a Scorpio with a T-9 transmission behind them. :)
410Fortune
ICE Season
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
That is correct!
However what is the difference as far as the trans is concerned?
If that trans bolts to a 1995 4.0 then it will bolt to a 96-2000 4.0
I have converted a few 2.9 ranger based vehicles to a 4.0, the 2.6/2.8/2.9/4.0 all can share transmissions (as far as I know) toyo kogo, mitsubishi, mazda 5 speed, c4/c5 auto, a4ld, 4r55e and 5r55e can all bolt up
Once you have the 8 bolt flywheel you can easily use the larger clutch or you can drill and tap 6 holes in it to use your old 2.9/4.0 10" clutch
Sounds like a sweet project! Not many Scorpio's still around
DPDISXR4Ti
New York
2005 Mountaineer
I'm pretty sure the Cologne 6-bolt flywheel from the Scorpio is not the same as the Ranger one. Worth verifying. Regardless, the T-9 uses a 23-spline input shaft which I don't think we'll find a clutch for other than the 10".
410Fortune
ICE Season
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
interesting! You are probably right...... I never got to mess with any of the 2.9 and 4.0 cars or RWD transmissions for that matter! Would be interesting to compare the flywheels
DPDISXR4Ti
New York
2005 Mountaineer
This thread got me to dig a little deeper and I've found that the Scorpio clutch is 9.5" while the Ranger 2.9 clutch is only 8.875". I'm not sure if the Scorpio flywheel is any heavier than the 2.9 Ranger - I'm guessing it might very well be - but it's certainly got a different bolt/pin pattern.
So in short, I believe I should be fine with the 2.9 Scorpio flywheel/clutch/starter behind the 4.0L OHV from a pre-'98 Aerostar or Ranger.
Trucker1998
Smyrna, delaware
1997 Explorer EB
Hi,
It is a six bolt pattern and there is a alignment dowel hole which really is seven , just remember to retorque your flywheel bolts
