UPDATE:
This is what myford recommends for the 60K service (at least for my 2000)........
Present Service: 60,000 Miles
Change automatic transmission fluid
Change engine oil and replace oil filter
Inspect and lubricate steering linkage, ball joints, suspension and, if equipped, half shafts drive shaft and u-joints
Inspect brake pads/shoes/rotors/drums, brake lines and hoses, and parking brake system
Inspect complete exhaust system and heat shields
Inspect engine cooling system and hoses
Inspect wheel ends for end play and noise
Lubricate 4x2 front wheel bearings, replace grease seals, and adjust bearings
Perform multi-point inspection
Replace engine air filter
Replace fuel filter
Rotate tires for optimal tire life
I'm fairly certain that it matches up with whats in the owners manual.
Whether or not you want all of that done, or can do any of it yourself is another matter entirely. I don't have a driveway, so most of the work on my X takes place in a shop.
Good Luck.
