Diff Whack Daddy
And the Roll Over Posse! Under the Hood Moderator
Moderator Emeritus
- February 19, 1999
- Mount Vernon, WA
- 1st Gen XLT 4dr
- Callsign
- KG7VTT
Help. I just spent $600 for new tires because I have a vibration at 60mph. The old tires were really bad, staring at 60 and getting progressivly worse. The new tires stop at about 62mph. Could this be caused by bad shocks? When I put the 5.5" superlift on, I retained the old Sears air shocks in the rear. The fronts are the superlift shocks. Is there a way to test to find out exactly where the vibration is coming from before I end up replacing everything. What about worn carrier bearing in the rear? U-joint(vibration there only at 60mph under power or coasting)? WHAT IS IT?
93XLT-5.5" Super Runner, Super Runner Steering, 1.5" Body lift,33x12.5,
Borla exhaust,KKM air filter, Warn HS9500i winch, Sony deck & 10 disk CD changer w/ 12" sub.
