List of Useful Threads - 6th Generation Ex and Aviator Recalls, TSB, FSA and SSM | Page 2 | Ford Explorer Forums - Serious Explorations
List of Useful Threads 6th Generation Ex and Aviator Recalls, TSB, FSA and SSM
Status
Not open for further replies.
TSB - SSM 49107 2020 Explorer/Aviator Easy Exit / Entry Seats
Some 2020 Explorer/Aviator vehicles built on or before 04-Sep-2019 equipped with memory seats may exhibit the driver front seat moving forward during easy entry/exit operation when the vehicle is turned off. This may be due to the software in the driver front seat module (DSM). To correct the condition, reprogram the DSM using the latest software level of the appropriate Ford diagnostic scan tool. For claiming, use causal part 14C708 and applicable labor operations in Section 10 of the Service Labor Time Standards (SLTS) Manual.
NOTE: this SSM has been updated but I don't have the info. Appear to have a software update for the seat controller logic.
Thanks to member markscalise & TonyST
Recall 20S65 Ford recall for 2020 Explorer and Aviator Driveshaft Issue
November 14, 2020 — Ford is recalling model year 2020 Explorers and Lincoln Aviators to find 18 vehicles equipped with driveshafts that may fracture along the weld seams.
To find those 18 vehicles, Ford is recalling more than 12,200 Aviators and Explorers to inspect the driveshaft labels and replace the defective driveshafts.
The automaker says the faulty driveshafts could lose their mechanical connections between the transfer cases and rear axles. This could cause the vehicles to roll away or experience a loss of motive power.
But the worst problem may be a fire from leaking fuel if the driveshaft deforms and separates from the driveline and strikes the fuel tank.
Ford says it doesn't know of any crashes, injuries or fires related to the defective driveshafts.
According to Ford, 10,905 Explorers and Lincoln Aviators are recalled in the U.S., about 1,291 are recalled in Canada and 102 are recalled in Mexico.
The recalled Explorers and Lincoln Aviators were built in Chicago between August 24 to September 30, 2019.
Ford hasn't announced when the recall will begin and the government hasn't provided details, but customers of Ford Explorers and Lincoln Aviators may call 866-436-7332.
The Ford driveshaft recall reference number is 20S65.
TSB 20-2220 Exhaust Rattle Noise – 2020 Ford Explorer & Lincoln Aviator
Exhaust Rattle Noise – 2020 Ford Explorer & Lincoln Aviator​
oemdtc September 14, 2020 No Comments
NHTSA ID Number: 10177124
Manufacturer Communication Number: TSB 20-2220
Summary​
Some 2020 Explorer/Aviator vehicles may exhibit a rattle type noise originating from the exhaust flexible pipe. This may be due to the natural harmonic frequency of the pipe. To correct the condition, follow the Service Procedure to install a worm gear clamp over the exhaust flexible pipe.
2 Affected Products
Vehicles​
MAKEMODELYEAR
FORDEXPLORER2020
LINCOLNAVIATOR2020
TECHNICAL SERVICE BULLETIN​
2020 Explorer/AviatorExhaust Rattle Noise
20-2220
29 June 2020
Model:
Ford
2020 Explorer
Lincoln
2020 Aviator
Issue: Some 2020 Explorer/Aviator vehicles may exhibit a rattle type noise originating from the exhaust flexible pipe. This may be due to the natural harmonic frequency of the pipe. To correct the condition, follow the Service Procedure to install a worm gear clamp over the exhaust flexible pipe.
Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
Parts
Part NumberDescriptionQuantity
Obtain Locally90 mm (3.5 in.) Worm Gear Clamp1 Per Exhaust Flexible Pipe
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
DescriptionOperation No.Time
2020 Explorer/Aviator: Install Clamp On The Flexible Pipe(s) Includes Time To Road Test To Verify Concern (Do Not Use With Any Other Labor Operations)202220A0.6
Hrs.
Repair/Claim Coding
Causal Part:5E212
Condition Code:42
Service Procedure​
  1. Open and install the worm gear clamp over the flexible portion of the exhaust flexible pipe. Tighten to 2.7 Nm (24 lb-in) (Figure 1).
Figure 1
1 Associated Document
Manufacturer Communications
20-2220
29 June 2020
Check for Recalls: Vehicle, Car Seat, Tire, Equipment
MC-10177124-0001.pdf 239.213KB
Thanks to member Dsle5403.
TSB #TSB 20-2291 - Reverse Brake Assist
This article supersedes TSB 20-2135 to correct the Service Procedure. Some 2020 Explorer/Aviator/Corsair vehicles built on or before 23-Jul-2020 may inadvertently activate the reverse braking assist system while backing up. This may be perceived as the system is too sensitive to surrounding objects. This may be due to the software in the image processing module B (IPMB). To correct the condition, follow the Service Procedure to reprogram the IPMB, as well as the accessory protocol interface module (APIM) to allow the vehicle to remember the last setting of reverse brake assist when the vehicle is restarted.
TSB 20-2403 - 10R60/10R80 transmission may exhibit a harsh engagement/harsh shift/delayed shift with or without DTCs
Model: 2020 Explorer/2020 Police Interceptor Utility/2020 Aviator
Issue: Some 2020 Explorer/Aviator/Police Interceptor Utility vehicles equipped with a 10R60/10R80
automatic transmission may exhibit a harsh engagement/harsh shift/delayed shift with or without an
illuminated malfunction indicator lamp (MIL) or diagnostic trouble codes (DTCs) P0729, P0731, P0732,
P0733, P0734, P0735, P0736, P076F, P07D9, P07F6, P07F7, P0751, P0756, P0761, P0766, P0771,
P2707, P2700, P2701, P2702, P2703, P2704 and/or P2705 stored in the powertrain control module
(PCM). This may be due to sticking valves in the main control valve body. Most vehicles will improve and
no longer exhibit the condition after the first 8,000 km (5,000 mi) of driving. To correct the condition, follow
the Service Procedure steps to perform the PCM - Transmission Accelerated Main Control Break In
routine for the appropriate clutch(s) and/or replace the main control valve body.
Action: Follow the Service Procedure steps to correct the condition on vehicles that meet all of the
following criteria:
• 2020 Explorer/Aviator/Police Interceptor Utility
• 10R60/10R80 automatic transmission
• At least one of the following symptoms:
- Harsh engagement
- Harsh shift
- Delayed shift
• With or without illuminated MIL and DTCs P0729, P0731, P0732, P0733, P0734, P0735,
P0736, P076F, P07D9, P07F6, P07F7, P0751, P0756, P0761, P0766, P0771, P2707,
P2700, P2701, P2702, P2703, P2704 and/or P2705 stored in the PCM
NOTE: Part quantity refers to the number of that service part number required, which may be
different than the number of individual pieces. Service part numbers contain 1 piece unless
otherwise stated. "As Needed" indicates the part is required but the number may vary or is not a
whole number; parts can be billed out as non-whole numbers, including less than 1. "If Needed"
indicates the part is not mandatory.
Parts
Part Number Description Quantity
L1MZ-7A100-B Main Control Valve Body (10R60) 1
L1MZ-7A100-A Main Control Valve Body (10R80) 1
XT-12-QULV Motorcraft® MERCON® ULV Automatic Transmission Fluid As Needed
Parts To Inspect And Replace Only If Necessary
Page 1 of 3
https://www.fordservicecontent.com/Ford_Content/vdirsnet/TSB/EU/~WTSB20-2403/US/... 12/1/2020
HL3Z-7A191-B Fluid Pan Gasket 1
LP5Z-7A098-A Fluid Filter (10R60) 1
L1MZ-7A098-A Fluid Filter (10R80) 1
HL3Z-7G199-A Auxiliary Pump Tube Seal 1
HL3Z-7J227-A Auxiliary Pump Tube O-ring 1
HL3Z-7A248-D Transmission Fluid Pump Seal 1
7T4Z-7Z302-A Transmission Fluid Filter Seal 1
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Emissions
Warranty/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP)
coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/Emissions
Warranty/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using
Labor Times
Description
Operation
No.
Time
2020 Explorer, Aviator 10R60 Transmission: Retrieve DTCs, Check Odometer And
Replace The Main Control Valve Body (Do Not Use With Any Other Labor
Operations)
202403A 2.8
Hrs.
Perform The Transmission Accelerated Main Control Break-In Routine Repair
Complete (Do Not Use With Any Other Labor Operations)
202403B 2.0
Hrs.
Perform The Transmission Accelerated Main Control Break-In Routine Replace The
Main Control Valve Body (Do Not Use With Any Other Labor Operations)
202403C 4.3
Hrs.
2020 Explorer 10R80 Transmission: Retrieve DTCs, Check Odometer And Replace
The Main Control Valve Body (Do Not Use With Any Other Labor Operations)
202403D 2.9
Hrs.
2020 Explorer 10R80 Transmission: Retrieve DTCs, Check Odometer And Perform
The Transmission Accelerated Main Control Break-In Routine Repair Complete (Do
202403E 2.0
Hrs.
The Transmission Accelerated Main Control Break-In Routine Replace The Main
202403F 4.4
Hrs.
Repair/Claim Coding
Causal Part: 7A100
Condition Code: 49
Service Procedure
NOTE: Most vehicles will improve and no longer exhibit the condition after the first 8,000 km (5,000
mi) of driving.
1. Does the vehicle have more than 8,000 km (5,000 mi) on the odometer?
(1). Yes - replace the main control valve body. Refer to Workshop Manual (WSM), Section 307-01.
Repair is complete.
(2). No - proceed to Step 2.
2. Are any transmission related DTCs present?
Page 2 of 3
(1). Yes - determine the appropriate clutch(s) to be cycled related to DTCs present. Refer to WSM,
Section 307-01.
(2). No - proceed to Step 4 to cycle all 6 clutches.
3. Record and clear all DTCs present before performing the PCM - Transmission Accelerated Main
Control Break In routine.
CAUTION: Failure to use a frame engaging lift could damage the vehicle.
4. Prepare the vehicle for PCM - Transmission Accelerated Main Control Break In routine by positioning
the vehicle on a frame-engaging lift with the wheels off the ground to prevent vehicle movement.
5. Using the latest software level of the appropriate Ford diagnostic scan tool, perform the PCM -
Transmission Accelerated Main Control Break In routine 3 times on the appropriate clutch(s) determined
to be cycled.
6. Perform the adaptive learning drive cycle. Refer to WSM, Section 307-01.
7. Does the vehicle still exhibit the condition after performing the PCM - Transmission Accelerated Main
Control Break In routine and adaptive learning drive cycle?
(1). Yes - replace the main control valve body. Refer to WSM, Section 307-01.
NOTE: Advise the customer this vehicle is equipped with an adaptive transmission shift strategy
which allows the vehicle's computer to learn the transmission's unique parameters and improve
shift quality. When the adaptive strategy is reset, the computer will begin a relearning process.
This relearning process may result in firmer than normal upshifts and downshifts for several days.
(2). No - repair is complete.
2020 Lincoln Aviator, Ford Explorer Police Interceptor Utility Recalled Over Contaminated Windshield Wiper Fluid​
SSM 49329 - 2020-2021 Explorer/Aviator- Intermittent No Crank, Remote Start Inoperative, Shift System Fault Message And/Or Illuminated Wrench Light With DTC P07E4, B135C And/Or U0103
Some 2020-2021 Aviator and Explorer vehicles may experience an intermittent no
crank, inoperative remote start, and/or an illuminated wrench light with diagnostic
trouble codes (DTCs) P07E4, B135C and/or U0103. This may be due to a loose
ground G210 and/or G214. Check grounds G210 and G214, refer to the Wiring
Diagramfor location information. If the concern persists, or the grounds are found to
be secure, refer to the Workshop Manual and applicable sections of the Powertrain
Controls/Emissions Diagnosis (PC/ED) Manual for normal diagnostics.
APPLICABLE VEHICLES
2020 CAR: TU U611A AVIATOR
2020 CAR: TZ U625A EXPLORER
2021 CAR: TV U611N AVIATOR
2021 CAR: TW U625N EXPLORER
TSB 20-2071 - 2020 Explorer / Aviator - AWD Various Warning Indicators C0633 and/or C00A6:07
Thanks to Dsle5403.
TSB 20-2363
Summary
This article supersedes TSB 20-2301 to update the vehicles affected.
Issue: Some 2019 MKZ, 2019-2020 EcoSport/Mustang/Continental/Fusion/F-150/Transit
Connect/Ranger/Edge/Nautilus and 2020 Escape/Corsair/Aviator/Explorer/Expedition/Navigator/F-Super
Duty vehicles with SYNC 3 may experience various SYNC performance related concerns including but not limited to:
• Wi-Fi connection message pop-up every key cycle
• Frozen unresponsive touchscreen
• Solid blue screen when moving forward at speeds above 16 km/h (10 mph)
• Rear parking aid camera remains on the screen at speeds below 16 km/h (10 mph)
• Inoperative infotainment applications
• Poor/no AppLink function
Page 1 of 4
• Apple CarPlay not launching on connection or a black screen when connected
• Voice prompts that skip or have short pauses while directions are being provided
• Sirius Travel Link™ not working properly with active subscription
• Remote start not able to be scheduled from FordPass or Lincoln Way
• Blank screen or frozen screen
• System states "In Michigan" when trying to select a Point Of Interest (POI) on the
navigation system
This may be due to the SYNC Software. To correct the condition, follow the Service Procedure to update
the accessory protocol interface module (APIM) software.
NOTE: Ford has found some of the APIMs replaced and returned for inspection contained an
outdated software level and the APIM did not require replacement. The customer concern may
have been resolved by updating the APIM with latest level of software. The SYNC 3 Universal
Thumb Drive will be able to update the APIM software without the use of a scan tool and does not
require the process to be monitored. Ford will be monitoring APIM replacements to confirm TSB
directed software updates have been performed.
following criteria:
• One of the following vehicle lines:
- 2019 MKZ
- 2019-2020 Continental/Edge/Nautilus/F-150/Fusion/Mustang/Ranger/Transit Connect
- 2020 Escape/Corsair/Aviator/Explorer/Expedition/Navigator/F-Super Duty
• Equipped with SYNC 3
• At least one of the following infotainment concerns:
- Wi-Fi connection message pop up every key cycle
- Frozen unresponsive touchscreen
- Solid blue screen when moving forward at speeds above 16 km/h (10 mph) (Figure 1)
- The rear parking aid camera remains on the screen at speeds below 16 km/h (10 mph)
(Figure 2)
- Poor/no AppLink function
- Apple CarPlay not launching on connection or a black screen when connected
- Voice prompts that skip or have short pauses while directions are being provided
- Sirius Travel Link™ not working properly with active subscription
- Remote start not able to be scheduled from FordPass or Lincoln Way
- Blank screen or frozen screen
- Infotainment system states "In Michigan" when trying to select a Point Of Interest (POI)
on the navigation system
Special Tool(s)
SYNC 3 Universal Thumb Drive
Labor Times
Description
Operation
No.
Time
Reprogram The APIM Using The SYNC 3 Universal Thumb Drive (Do Not Use
202363A 0.3
Hrs.
Page 2 of 4
Repair/Claim Coding
Causal Part: 14G371
Condition Code: 04
Service Procedure
Figure 1
Figure 2
1. Disconnect all customer connected USB items from all media hub locations.
2. Start the vehicle.
3. Insert the SYNC 3 universal thumb drive into the USB port on the media hub.
4. The module automatically updates with no user input required.
(1). Modules already at the latest software level will indicate this after approximately 30 seconds.
(2). Module programming for a non-updated module does not need to be monitored and can take
approximately 20-30 minutes.
(3). Once the reprograming has completed, the screen will display a message indicating the module is
up to date.
5. Remove the SYNC 3 universal thumb drive when complete. The screen returns to the SYNC 3 home
screen. Reconnect any of the customer USB items. No vehicle or system restarts are required.
© 2020 Ford Motor Company
All rights reserved.
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge,
tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or
provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do
not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the
Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended
Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was
Page 3 of 4
current at the time of printing. Ford Motor Company reserves the right to supersede this information with updates. The most recent
information is available through Ford Motor Company's on-line technical resources.
Thanks to Dale, Dsle5403.
Recall 21S34 – Battery Cable Wire Harness Inspection – 2020-2021 Lincoln Aviator​
July 22, 2021
July 15, 2021 NHTSA CAMPAIGN NUMBER: 21V534000
Unsecured Wire Harness
Damaged electrical wires may short-circuit, increasing the risk of a fire.
NHTSA Campaign Number: 21V534
Manufacturer Ford Motor Company
Components ELECTRICAL SYSTEM, VISIBILITY
Potential Number of Units Affected 33,298
Summary
Ford Motor Company (Ford) is recalling certain 2020-2021 Lincoln Aviator vehicles equipped with 3.0L gasoline engines. The wire harness may not be secured properly, possibly contacting the air conditioning (A/C) compressor pulley, and resulting in damage to electrical wires, or the A/C compressor drive belt.
Remedy
Dealers will inspect the harness and A/C compressor belt for damage, replacing them as necessary, and install a tie strap to secure the wire harness, free of charge. Owner notification letters are expected to be mailed July 30, 2021. Owners may contact Ford customer service at 1-866-436-7332. Ford’s number for this recall is 21S34.
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.nhtsa.gov.
Recall 21S44 - 2020-2021 AVIATOR, EXPLORER, CORSAIR-REAR/360 CAMERA IPMB BLUE SCREEN
Issue Date SEP 23, 2021
Safety Risk
AN UNUSED GENERAL PURPOSE OUTPUT PIN ON THE DIGITAL CAMERA WAS LEFT OPEN. IF THIS PIN IS NOT PULLED LOW IT MAY BE AFFECTED BY LEAKAGE CURRENT, RESULTING IN A LOSS OF VIDEO OUTPUT. LOSS OF REAR CAMERA IMAGE WHILE REVERSING INCREASES THE RISK OF A CRASH.
Remedy
OWNERS WILL BE NOTIFIED BY MAIL AND INSTRUCTED TO TAKE THEIR VEHICLE TO A FORD OR LINCOLN DEALER TO HAVE THE IMAGE PROCESSING MODULE IPMB SOFTWARE UPDATED. THERE WILL BE NO CHARGE FOR THIS SERVICE.
Campaign/NHTSA# 21S44/999999
(Thanks to Sgt1411)
Recall 21E11 - 2020 - 2021 Explorer 3.0L Inlet Exhaust Leak
MANUFACTURER RECALL
RECALL 21E11
Emissions Recall: 2020-21 EXPLORER 3.0L LH INLET EXHAUST LEAKS
Limited info available at this time. Will expand once more is found out.
SSM 49953 - 2021 Explorer ST/Aviator - Engine Sound Enhancement (ESE)/Active Noise Control (ANC) Inoperative - Built On Or Before 07-Jun-2021
Some 2021 Explorer ST and Aviator vehicles may exhibit a customer concern of undesirable powertrain sounds inside the vehicle and/or less than optimal speaker sound from the vehicle. This may be due to the engine sound enhancement (ESE) on Explorer ST vehicles and the active noise control (ANC) on Aviator vehicles not being activated. To correct the condition, use the Ford Diagnosis and Repair System (FDRS) > select Toolbox > ACM > ACM - Enable Engine Sound Enhancement and Active Noise Control. Click RUN and follow the on-screen instructions carefully. If prompted with a window stating Feature Not Supported, select OK and continue through the installation application. For claiming use causal 18K810 and applicable labor operations found in Section 10 of the Service Labor Time Standards (SLTS) Manual.
APPLICABLE VEHICLES
2020 - 2021 CAR: TV U611N AVIATOR
Thanks to Pedro504.
Recall 22S27 Rear Axle Bolt Fractures
Certain Ford Explorers 2020-22
TSB 21-2276
TSB 22-2144 Power Adjustable Steering Column Noise 2020 Explorer / Aviator
Status
