6x8's or 5 1/4's?
blitzk
Florida
04 XLT
I ordered the 2 Infinity perfect 12.1's, and the 611A amp to drive it.
I also have the 7541A amp on order to drive the 4 door speakers.
My only thing I'm hung up on is if I should get the Infinity kappa 6x8's or 5 1/4" components?
(6x8) Kappa 680.7cs:
MSRP U.S. $: 349.95
Power Handling, RMS: 90 Watts
Power Handling, Peak: 270 Watts
Sensitivity: 94dB
Frequency Response: 45Hz - 25kHz
Mounting Depth: 2-1/4"
Impedance: 2 Ohms
(5 1/4) kappa 50.7cs:
MSRP U.S. $: 329.95
Power Handling, RMS: 85 Watts
Power Handling, Peak: 255 Watts
Sensitivity: 94dB
Frequency Response: 55Hz - 25kHz
Mounting Depth: 2-1/16"
Impedance: 2 Ohms
...thoughts?
Dissolved
Orange County, CA
'99 XLS
blitzk
Florida
04 XLT
if you gonna spend so much on the system i would get the 6.5" ones. more bass, and you can mount the tweaters in the door moldings. might have to fab a bracket tho.
With those 2 amps, are you going to run a cap or a stronger battery?
im looking into a very sim setup and is curious, im new on this stuff.
http://www.crutchfield.com/S-unLz596aXSo/cgi-bin/Prodview.asp?c=3&g=410&I=108607CS&s=0&cc=01
OK, so what all is involved with getting a 6 1/2" to fit in a 3rd gen door?
...and is it the same process for the front and rear doors?
With the 2 amps I'm installing an optima red top battery, and yes I will
install a cap (even if it's useless, there will be one there). I'm running a
4-guage wire to the amps from the battery....
JasonF
2004 XLT 4x4 4.0
Search for my thread entitled "component install pics" for details on putting in my 6.5" Boston SL60's.
ford freak
coplay,pa
2004 xlt
Here ya go.http://www.installer.com/speakerparts/part#82-5600
blitzk
Florida
04 XLT
Thanks... I guess I should have updated the thread.
I have the adapters, and I ordered the 60.7cs speakers over the weekend.
