2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Initial installation
I performed some voltage checks on my stock throttle body before replacing it. The voltage with ignition On, engine Off at closed throttle was 0.97 volts. That's slightly more than desired according to what I've read on this forum. At wide open throttle (WOT) the reading was 4.7 volts. The photo below shows the racing 75mm throttle body installed with a 1997 Expedition throttle position sensor (TPS) installed.
Visible in the photo are the M5-0.80x30 socket head cap screws (instead of the stock Phillips head) I purchased from Lowe's to mount the TPS to the throttle body. The photo below shows the 75mm throttle body with closed throttle.
The thickness of the tapered adapter was just right for virtually no cable slack with the throttle control against the closed stop screw. The voltage reading at closed throttle is 1.03 volts (higher than I want). I noticed before using my Dyno-Scan that absolute throttle position was 18.8% for the stock throttle body at closed throttle.
The photo below shows the 75mm throttle body at WOT after connecting the throttle cable.
I wedged a pole between the accelerator and the seat back to check the throttle plate movement. The throttle control was against the WOT stop. The voltage at WOT is 4.7 volts. As I recall this equated to an absolute throttle position of 92.8%. I disconnected the negative battery terminal and then connected the cruise control cable and attached the main intake hose and associated hoses as shown below.
It was fairly difficult to force the stock intake tube over the larger than stock outside diameter of the 75mm throttle body. I had thoroughly warmed up my engine before replacing the stock throttle body to insure the engine wouldn't die when started with the 75mm throttle body. I reconnected the negative battery cable after more than 10 minutes and started the engine. The engine started fine and idled about the same (not stable and slow) as it did with the stock throttle body. I let it idle for 15 minutes so the PCM could begin to "learn" the new throttle body. During this time I watched the A/F ratio and detected nothing abnormal. I then spent about 10 minutes switching from Park to R to N to D to N to R to N to D letting the PCM further "learn" the new TPS and throttle body. Then I ran the engine at various speeds under 3,000 rpm. During all of this I watched the A/F ratio and nothing looked abnormal. Then I did a couple of throttle "blips" but still nothing over 3,000 rpm. The throttle response seems improved and the intake air flow noise is definitely increased. The noise increase could be partially due to the elimination of the "comb" gasket. No CEL was ever illuminated.
Next comes a test drive with my Dyno-Scan to monitor O2 sensors, absolute throttle position, MAF airflow and to watch the A/F ratio. I'll also check the cruise control to see if the cable needs to be adjusted.
I'm not satisfied with the larger closed throttle TPS voltage but I don't want to drill out the bushings to perform the slot adjustment mentioned on this forum. I think the bushings are an integral part of the physical strength of the TPS. I'll play with my stock TPS to try and find an alternative method.
