- January 14, 2001
- Fresno CA
- 86 ranger no more
- Callsign
- KK6TDL
So my ranger has a 28 spline 8.8 rear axle with drum brakes. I am planning on swapping a dana 44 into the front but it is a 6 lug bolt pattern. So I need to figure out how to change all the lug patterns and make it work. Here is my plan tell me where i may or may not be wrong and if you can answer a few questions I have all the better.
I am planning on using my stock housing. I am thinking of ordering custom axle shafts such as superior, moser, or someone else and have them put the 6 on 5.5 bolt pattern I need on them and then make them 31 spline shafts aswell. Get an open diff 31 spline carrier and weld it up. Now I have 31 spline alloy axles (much stronger then stock) and have the bolt pattern I need to match the front. I also wont have to run anytype of wheel spacer in the rear.
My question is what do I do for my brake drums. Can I have them redrilled by a machine shop to accept the new 6 lug pattern? If I cant do that I could swap over to disk brakes but then I loose my e-brake and add alot more to the cost of the project. Anyone have any other suggestions or ideas?
