Fordtruckfan89
- February 17, 2012
- NC
- 1994 Explorer XLT 4-Dr
My 03 sport Trac decided to eat a spider gear, figured while I was replacing them I'd do the Trac loc clutches, at 300k they're shot. Im mechanically inclined but I've never had to mess with a rear axle til now.
I found when I went to install the new clutch packs ( ford carbon fiber versions) I couldn't get the new spider gears to roll into the carrier unless I left the shims out that go between the carrier and outer clutch plate.(Stacked as per the instructions)
One shim is a .025 and ones a .030. Tried taking a bolt and nut to compress the clutches/spread the gears and make it easier. It didnt help. The spider gear set is from Yukon gear. What am I doing wrong? I assembled it for right now without shims but I imagine it's not as tight as it should be.
