84 Bronco II Eddie Bauer with shifter issues. | Ford Explorer - Ford Ranger Forums - Serious Explorations
patrickd
sparta wisconsin
84 bronco ii eddie bauer
I recently picked up this truck and while off roading my shifter keeps going "free". I lose all gears and the shifted moves freely. It happened when I first got it and the rubber bushing inside the shifted was destroyed. After the second happening I pulled the shifter expecting the same this and the bushing was fine. any body have any ideas on what the issue could be.
NHarris
Gillette, Wyoming
04 Wrangler, 08 Ranger
welcome to the forum!
Probably want to head over to the Bronco II section.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
FutureX
SF Bay Area CA
87 BII XLT 4x4
is this a 5speed or A4LD ?
A4LD (Auto trans) possibly shifter motor fried, or the clutches dead...
5speed, check the shift linkage maybe it fell apart?, also i dunno if the BII 5speeds have it, but maybe a broken guide pin? .... also could be a Clutch problem most likely time for a new one...
patrickd
sparta wisconsin
5 speed. Or 4 with an overdrive. Manual.
rookieshooter
Moderator Emeritus
Martinsburg WV
84 BII "Li'l Samson"
Your transfer shifter is not slipping back to the neutral position is it?
Mine has done this on occasions, and then you get nothing.
