Pleasantwilliam
- August 2, 2014
- 85 Ford Ranger
Hello folks.I would appreciate any info regarding transmission/transfer case/clutch on a recently purchased Ford Ranger.Ill explain the best I can.The truck was gifted to a teenage girl by her grandfather,she owned it 2 weeks,truck supposedly ran well,then suddenly stopped moving.Someone told her she needed a new clutch,and she decided to sell vs.fix. So this is where I came in.Had the truck towed to the house and started going through the checklist.The clutch feels fine to me.I checked the fluids clutch/trans.Although a little dirty,they were full.The shifter(manual) goes through all the gears no problem.I removed shifter from transfer case and inspected.No broken parts or anything obvious.When the shifter is in the neutral position,I am able to turn the drive shaft by hand(level ground) It seems as though its still in gear as it engages the differential.The truck starts and runs fine,just doesn't move.Nor does it feel like clutch/gears are engaging when the motor is running.My thoughts are that the girl didn't know how to drive a stick shift and forced/broke something.Any ideas?Truck has 97,000 miles and looks as though it has been maintained.Is it possible that the truck can be in gear yet I am able to run the truck without any movement?Its my understanding that you are supposed to engage the clutch in order for it to run,this is not the case.Truck starts without having to depress the clutch? Argghhhh....
