96stroker
- September 9, 2006
- Glenwood, IA
- 1993 XLT
Hey guys my Bronco has acted up since I got it. I have to try to start it 4 or 5 times before it will stay running. But when it does start and run after those 4 or 5 times it only runs for about 3 seconds then dies. Another 3 or 4 times of trying to start it makes it start and run fine after that. The codes I have pulled off it are codes 13 & 33 with the key on engine running and code 67 with the key on engine off. Any thoughts? I'm thinking EGR valve but would that cause my problems? I already pulled of the IAC and cleaned it along with the throttle body and the EGR valve too. I tuned it up(plugs,wires,cap,rotor,oil) a month ago and replaced the EGR valve position sensor too because that was one of my codes before. That didn't help a bit. Any help would be appreciated. Thanks!
