91-09 Explorer 5" of lift for under 300.00
Maniak
Moderator-Stock 91-94
Staff member
Moderator
Vail, Arizona
1992 XLT 4x4
Found Danny boy's thread on soa conversion. Curious though, will the conversion itself raise the rear of my explorer any?
Just moving spring from on top of the axle to under the axle and changing nothing else will raise it 5.5" or so.. (Going from SUA to SOA).
~Mark
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
albi1cnobi1
Elite Mountaineer
South Jersey
99 Mountaineer V6 4x4
Yes, just the conversion itself will raise the rear of the truck approximately 5".
Edit:
Oops, didn't see your post Mark. What he said!
Stazz75
97 Explorer XLT 5.0
Then how would I lift the front to match it without doing sas?
Maniak
Staff member
Moderator
Vail, Arizona
1992 XLT 4x4
Your only option for your generation Explorer is a sloped body lift with cranked torsion bars or a lift kit in combination with a sloped body lift (info about that in the 1st post of this thread)
~Mark
imacker35
Texas
01 Ford Explorer Sport
Will all of these modifications fit my 01 Sport? This seems to be the only forum on the web that knows their stuff so I'm hoping someone here knows!
03Sport
Augusta, GA
2003 Ford Explorer Sport
Looking for AAL for 2003 Sport XLT the website linked on the first pages says the EXP13120 AAL won't fit my vehicle.
03Sport
Augusta, GA
What are you looking to do to your Explorer? I have a 2003 Sport and have Torsion Keys, Torsion Twist and 2" Shackles in the rear. This is definitely the site to help you out.
imacker35
Texas
I'm looking to get it lifted and put some 33 inch A/Ts on it. About 3-5 inches of lift just so I can have some fun with my friends and their trucks when they go off-roading and all that.
03Sport
Augusta, GA
Sounds like you may want to do a body lift, go back to page 1 of this thread and all the info on the body lift is there.
joshpatzer2
fort wayne IN
1999 ford explorer awd
im running lift shackles and a tt lift and i have between 32"-33" tires. going to do a 3" body lift and some creative "clearance cutting" and i think i should be able to fit 35" tires. i have a 1999 explorer V-8 AWD though, so i think they sit a little higher than the 6 cylinder ones.
Stazz75
97 Explorer XLT 5.0
Ok so I can't remember, do I need 883 or 853?
Stazz75
97 Explorer XLT 5.0
Anybody know? I ordered the 853 but if I need the 883 I can exchange it
albi1cnobi1
Elite Mountaineer
South Jersey
You need the 883.
Stazz75
97 Explorer XLT 5.0
What's the difference between the two, just the bumper brackets?
Stazz75
97 Explorer XLT 5.0
Anybody got a diagram for the radiator brackets? I can have them made..
mksu19
Bay Area, Cali
'96 Eddie Bauer/'08 M3
...If your truck is a 1995-1997 you need part # PA-853 for the ford ranger, If your truck is a 1998-2001 you need part # PA-883 for the ford ranger. I purchased mine from www.suspensionconnection.com
Click on body lifts, ford body lifts, then ranger...
Can someone please confirm if the parts number is correct? I only see a part #833 and not #883 on Summit's website. Thanks!
EDIT: Better yet, can someone please post the link to the part(s) I need for my 1999 Explorer 4DR 4.0. Thanks again!
97Mounty97
Port Huron, MI
2004 Ford Explorer
this helps a lot
Thompstomper
Amarillo, Texas
1997 Frankeneer
Good Write up here.
Just Doesnt hit on the 97 Mountaineer 5.0 AWD BL
I'm Guesing that the 1997 Mountaineer is just like the AWD 1998 explorer.
So I need the 883 BL too right?I did the TT and Made rear shacles..So they are a little stouter than the warrior shackels and a 1/2'' longer.
With the BL and what I have already done...Im going to atempt 36's with some excessive wheel well trimming.
Just needing to know for sure what BL kit to buy.
Thanks. Jay
C Unorthodox lift for a 07 explorer Eddie Bauer Shocks, Suspensions, Lift Kits 7
X Body Lift for 99 explorer? Shocks, Suspensions, Lift Kits 1
E Want to lift my 2003 explorer Shocks, Suspensions, Lift Kits 1
A Wanting to lift my 2005 explorer Shocks, Suspensions, Lift Kits 1
D Rear Lift issues on a 2000 Explorer Sport Shocks, Suspensions, Lift Kits 2
R 99 2wd explorer lift Shocks, Suspensions, Lift Kits 0
F 2001 Ford Explorer Sport Lift? Shocks, Suspensions, Lift Kits 3
T 2006 explorer lift kit Shocks, Suspensions, Lift Kits 0
J looking for a 99 ford explorer xlt lift kits Shocks, Suspensions, Lift Kits 0
R 1998 Explorer Lift Shocks, Suspensions, Lift Kits 6
N lift kits for 08 explorer xlt Shocks, Suspensions, Lift Kits 1
S help on 2Wd lift on 93 explorer Shocks, Suspensions, Lift Kits 0
S 04 Explorer XLT lift suggestions? Shocks, Suspensions, Lift Kits 4
C 2004 Explorer lift kit help with shocks Shocks, Suspensions, Lift Kits 0
L 2002 Ford Explorer Sport BODY LIFT???? Shocks, Suspensions, Lift Kits 1
T Need advice on bigger lift (92 explorer) Shocks, Suspensions, Lift Kits 1
N 1993 Ford Explorer Xlt 4x4 budget lift? Shocks, Suspensions, Lift Kits 11
E will this lift work on my 98 explorer? Shocks, Suspensions, Lift Kits 4
9 How do I lift my 1998 limited Ford Explorer? Shocks, Suspensions, Lift Kits 2
R 2001 Explorer Sport lift. Shocks, Suspensions, Lift Kits 13
M 2000 Ford Explorer lift. Shocks, Suspensions, Lift Kits 2
W 1997 Explorer Sport. I want to lift it. Shocks, Suspensions, Lift Kits 7
S 2" body lift on a 94 explorer Shocks, Suspensions, Lift Kits 0
S 05 Explorer lift ideas Shocks, Suspensions, Lift Kits 5
D 2001 Explorer XLS lift kit and tires question Shocks, Suspensions, Lift Kits 14
C How do I lift a 1999 Explorer? Shocks, Suspensions, Lift Kits 21
T 2004 Ford Explorer. Lift help is needed. Shocks, Suspensions, Lift Kits 5
T 2002 Explorer body lift. Shocks, Suspensions, Lift Kits 5
C 2000 explorer sport lift Shocks, Suspensions, Lift Kits 0
N How do I put in some Lift to my Explorer Shocks, Suspensions, Lift Kits 6
V 3rd generation ford explorer lift?? Shocks, Suspensions, Lift Kits 2
R 1998 Explorer body lift. Shocks, Suspensions, Lift Kits 3
J I want to lift my 2003 Explorer Sport. Shocks, Suspensions, Lift Kits 13
V Biggest 94 Explorer Lift Shocks, Suspensions, Lift Kits 7
1 Lift for a 97 Explorer Sport Trac with 4WD. Shocks, Suspensions, Lift Kits 8
H Which lift could I use on my 1994 Explorer? Shocks, Suspensions, Lift Kits 2
D need help 98 explorer Lift Shocks, Suspensions, Lift Kits 1
Govna47 Body Lift 2001 Explorer Sport Shocks, Suspensions, Lift Kits 3
J should i get a suspension lift for a '98 ranger instead of explorer? Shocks, Suspensions, Lift Kits 8
R Body lift for a 99 Explorer limited? Shocks, Suspensions, Lift Kits 20
5 02-05 explorer body lift part## Shocks, Suspensions, Lift Kits 2
E Lift kit for a 1996 Explorer. Shocks, Suspensions, Lift Kits 1
F do they even sell a lift for a 2001 explorer sport i cant find one anywhere Shocks, Suspensions, Lift Kits 6
W explorer, ranger, sport trac lift kit differences Shocks, Suspensions, Lift Kits 2
A 97 Explorer Eddie Bauer AWD 5.0. I want to lift it. Shocks, Suspensions, Lift Kits 6
V ranger lift on explorer Shocks, Suspensions, Lift Kits 0
M looking for a cheap and easy way to get a lift for a 1999 ford explorer Shocks, Suspensions, Lift Kits 1
P Need Help! Cant find a lift kit for a 2001 Explorer XLT Shocks, Suspensions, Lift Kits 1
Q 1991 Ford Explorer stock. How much is a lift kit? Shocks, Suspensions, Lift Kits 1
C 2002 4x4 Explorer Eddie Bauer body lift??? Shocks, Suspensions, Lift Kits 4
Similar threads
