91-09 Explorer 5" of lift for under 300.00
albi1cnobi1
Elite Mountaineer
South Jersey
99 Mountaineer V6 4x4
Half a lift?
:usa:
Hey everyone.
This may sound like a stupid question but here goes any way. I can't afford bigger tires right now and honestly my 4 wheeling is not that aggressive. I have a TT and shackles installed on my 99 Mounty so I only want to go a little higher, maybe 1 to 2 inches. Has any one ever thought of cutting the body spacers in half. Another 1 1/2" would do me just fine. All of the pucks I've seen are molded all the way through, and I have access to precision cutting equipment so thats not an issue. Any comment, ideas, input would be great.
Thanks, Al
fordlover3
AZ
99 X Eb 4.0 SOHC 4x4
oh yeah sorry i have a 99 Eb 4wd and just a few inches would be fine since you can only go about 1.75 in. with the TT
99ex22
Wilsonville, Oregon
2000 5.0L 4x4 Eddie Bauer
Yeah I did it with my 99, I cut the 3" pucks down to 1". MORE off road sells 1" pucks for 4.00 each.
albi1cnobi1
Elite Mountaineer
South Jersey
:usa:
Hey 99ex22,
Thanks for the info on M.O.R.E. offroad. They are nice aluminum pucks, but I'm wondering about the aggravation factor of buying just the pucks. i.e. bumper brackets etc. If I bought the kit and cut them down I could alter the kit brackets as opposed to fabricating new ones. What do you think. I'm open for suggestions.
Thanks, Al
Guard24
Moneta Va
96 explorer sport
Hey all,
I'm going to shackle and TT my 96 explorer sport, but if 2" isn't enough, and I wanted to add maybe just one-two more inches, is there any way to do it without a kit, or do i have to get a 2" kit and add for four inches.
-Also, does anyone have any pics of a 2" explorer sport (TT and shackles)? I'd love to see what it looks like before the money comes out haha.
Thanks in advance!
Lee
albi1cnobi1
Elite Mountaineer
South Jersey
:usa:
Hey Guard,
I don't have a sport but I can post pics of my 99 Mounty with TT and shackles if you want to get an idea of the look. Let me know, I'll have to figure it out I haven't posted pics in a post yet. As a side note you wont get a full 2" out of the shackles, and you shouldn't crank the front bars up a full 2" or you are going to severely shorten the life of the CV joints. I would go 1.5" or 1.75" max.
Al
Guard24
Moneta Va
96 explorer sport
That would be great Al!
And thanks for the advice, makes sense to go a tad lower than two.
and i would appreciate before and after pics, if you have any (for comparison)
but anything at all would help out alot.
i took a jack and put the body up 2 inches today, looked pretty good, although i think that bigger tires would really make the difference
to all:
what did you think of the lift when you did TT/shackles?
albi1cnobi1
Elite Mountaineer
South Jersey
:usa:
Hey Guard,
No problem. Sorry I didn't get back sooner, working crazy hours. I don't know if I have before pics but I'll take some after pics as soon as I can. I lucked into a brand new set of BFG All-Terrains, stock size. But with the AT's aggressive look they appear bigger. Get those pics up asap.
Al
99ex22
Wilsonville, Oregon
:usa:
Hey 99ex22,
Thanks, Al
You don't need brackets or anything for just a 1" body lift. Most everything has enough adjustment to get it up another inch. The only thing I had to do was make the holes in the front of the frame where the bumper mounts a little bigger so I could raise it up.
albi1cnobi1
Elite Mountaineer
South Jersey
:usa:
Hey 99ex22,
What did you do for body bolts? Is there enough length on the stock bolts?
Thanks, Al
99ex22
Wilsonville, Oregon
You need two 5 1/2" bolts and nuts for the 2 front mounts (you have to drill the mounts out to 1/2") And for the mounts behind the front seats you need to go to the junk yard and pull the bolts out of a explorer from the very rear of the cargo area (they're longer) all the other bolts will work just fine! You don't need to extend anything either, everything stays in the stock location.
albi1cnobi1
Elite Mountaineer
South Jersey
:usa:
Hey 99ex22,
Thanks for the info. I think I'll probably go that route.
Al
albi1cnobi1
Elite Mountaineer
South Jersey
:usa:
Hey 99ex22,
Your ex looks great! I have a question. I have the 5r55e tranny, will that BW 4406 fit behind mine? If so what is involved. ( different drive shafts etc.) Is it a direct bolt in except for the shift linkage? Again your rig looks outstanding, great job.
Al
99ex22
Wilsonville, Oregon
No it won't work on yours. Also there would be no point in doing it as you already have lo range.
albi1cnobi1
Elite Mountaineer
South Jersey
99ex22,
I was really just looking to switch to a manual shift t-case. But in doing some research I think the BW 1354 will work better for me.
Thanks, Al
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
1975 Ford Bronco 4x4
Shinylion
Calhoun, Georgia
Exlorer Sport 2002
Great info man! im a noob, and this really did clear a lot of things up for me so thank you!
Quick question though....i have a 2002 explorer sport manual. will everything you have in your post still apply to me? i have no idea what applies to me, because people tell me to go to the 1995-2001 forum. then when i tell people i have a third gen, they say i can do anything that 2nd gen owners do to lift their explorer...? can you clear up this whole sport thing for me?
gmanpaint
It's Always Something!
Staff member
Moderator
MO MO
94 & 95 XLT's
Your Sport is technically a 2nd gen. Sports til 2003 are the remainder of the 2nd gens, even though they are past the 2001 models.
You have a solid axle in the rear, as the 3rd gens have independent rear suspension, (IRS-(C/V axles, control arms, hubs) and a few other changes in the suspension.
Shinylion
Calhoun, Georgia
Exlorer Sport 2002
alright thanks man i really appreciate it. so whatever 2nd gen sport owners use to lift their explorer, i can use the same things?
C Unorthodox lift for a 07 explorer Eddie Bauer Shocks, Suspensions, Lift Kits 7
X Body Lift for 99 explorer? Shocks, Suspensions, Lift Kits 1
E Want to lift my 2003 explorer Shocks, Suspensions, Lift Kits 1
A Wanting to lift my 2005 explorer Shocks, Suspensions, Lift Kits 1
D Rear Lift issues on a 2000 Explorer Sport Shocks, Suspensions, Lift Kits 2
R 99 2wd explorer lift Shocks, Suspensions, Lift Kits 0
F 2001 Ford Explorer Sport Lift? Shocks, Suspensions, Lift Kits 3
T 2006 explorer lift kit Shocks, Suspensions, Lift Kits 0
J looking for a 99 ford explorer xlt lift kits Shocks, Suspensions, Lift Kits 0
R 1998 Explorer Lift Shocks, Suspensions, Lift Kits 6
N lift kits for 08 explorer xlt Shocks, Suspensions, Lift Kits 1
S help on 2Wd lift on 93 explorer Shocks, Suspensions, Lift Kits 0
S 04 Explorer XLT lift suggestions? Shocks, Suspensions, Lift Kits 4
C 2004 Explorer lift kit help with shocks Shocks, Suspensions, Lift Kits 0
L 2002 Ford Explorer Sport BODY LIFT???? Shocks, Suspensions, Lift Kits 1
T Need advice on bigger lift (92 explorer) Shocks, Suspensions, Lift Kits 1
N 1993 Ford Explorer Xlt 4x4 budget lift? Shocks, Suspensions, Lift Kits 11
E will this lift work on my 98 explorer? Shocks, Suspensions, Lift Kits 4
9 How do I lift my 1998 limited Ford Explorer? Shocks, Suspensions, Lift Kits 2
R 2001 Explorer Sport lift. Shocks, Suspensions, Lift Kits 13
M 2000 Ford Explorer lift. Shocks, Suspensions, Lift Kits 2
W 1997 Explorer Sport. I want to lift it. Shocks, Suspensions, Lift Kits 7
S 2" body lift on a 94 explorer Shocks, Suspensions, Lift Kits 0
S 05 Explorer lift ideas Shocks, Suspensions, Lift Kits 5
D 2001 Explorer XLS lift kit and tires question Shocks, Suspensions, Lift Kits 14
C How do I lift a 1999 Explorer? Shocks, Suspensions, Lift Kits 21
T 2004 Ford Explorer. Lift help is needed. Shocks, Suspensions, Lift Kits 5
T 2002 Explorer body lift. Shocks, Suspensions, Lift Kits 5
C 2000 explorer sport lift Shocks, Suspensions, Lift Kits 0
N How do I put in some Lift to my Explorer Shocks, Suspensions, Lift Kits 6
V 3rd generation ford explorer lift?? Shocks, Suspensions, Lift Kits 2
R 1998 Explorer body lift. Shocks, Suspensions, Lift Kits 3
J I want to lift my 2003 Explorer Sport. Shocks, Suspensions, Lift Kits 13
V Biggest 94 Explorer Lift Shocks, Suspensions, Lift Kits 7
1 Lift for a 97 Explorer Sport Trac with 4WD. Shocks, Suspensions, Lift Kits 8
H Which lift could I use on my 1994 Explorer? Shocks, Suspensions, Lift Kits 2
D need help 98 explorer Lift Shocks, Suspensions, Lift Kits 1
Govna47 Body Lift 2001 Explorer Sport Shocks, Suspensions, Lift Kits 3
J should i get a suspension lift for a '98 ranger instead of explorer? Shocks, Suspensions, Lift Kits 8
R Body lift for a 99 Explorer limited? Shocks, Suspensions, Lift Kits 20
5 02-05 explorer body lift part## Shocks, Suspensions, Lift Kits 2
E Lift kit for a 1996 Explorer. Shocks, Suspensions, Lift Kits 1
F do they even sell a lift for a 2001 explorer sport i cant find one anywhere Shocks, Suspensions, Lift Kits 6
W explorer, ranger, sport trac lift kit differences Shocks, Suspensions, Lift Kits 2
A 97 Explorer Eddie Bauer AWD 5.0. I want to lift it. Shocks, Suspensions, Lift Kits 6
V ranger lift on explorer Shocks, Suspensions, Lift Kits 0
M looking for a cheap and easy way to get a lift for a 1999 ford explorer Shocks, Suspensions, Lift Kits 1
P Need Help! Cant find a lift kit for a 2001 Explorer XLT Shocks, Suspensions, Lift Kits 1
Q 1991 Ford Explorer stock. How much is a lift kit? Shocks, Suspensions, Lift Kits 1
C 2002 4x4 Explorer Eddie Bauer body lift??? Shocks, Suspensions, Lift Kits 4
Similar threads
