http://www.autozone.com/autozone/pa...2?counter=1&itemIdentifier=296117_82191_7849_
I am guessing they are probably made by the same wire harness place no matter where you buy them.
..If this was in fact the case, Walmart would be the best price but this is
not true at all...This would be a good time to compare these two same cables...
...Auto parts stores do and will change suppliers, and stores like Autozone will buy from the cheapest manuf/supplier...Stores like Napa and Kragen/Shucks/O'reilly for the most part will have quality parts available from different manuf. and will carry these same parts for years while standing behind their product...
...Napa cable found in most Napa stores or can be had in an hour...
Specs..
Part Number: CBL 717991
Price: 26.99
Price
Unit
Features & Benefits
Made In USA, Premium Quality, Synthetic Rubber Jacket (Not PVC Or Vinyl).
Warranty Limited Lifetime for Passenger Cars and Light Trucks
Attributes Battery Cable End Type : Lead-Free Top Post
Battery Cable Gauge(s) : 4
Battery Cable Length :
50"
Auxiliary Lead : 8 ga x 23" w/ 3/8" Ring
Auxiliary Lead 2 : 12 ga 2 Pin 14" OE Type
Hazards or Warnings : Battery Posts, Terminals, & Related Accessories Contain Lead & Lead Compounds, Chemicals Known To The State Of California To Cause Cancer & Reproductive Harm. Wash Hands After Handling!
Lug Hole Diameter : 13/32"
Main Cable Notes : 30" From Battery Terminal To Center Lug, 3/8" Lug Hole
Material Safety Data Sheet There is no MSDS for this item
Application Information: 1991 Ford Truck Explorer
Per Car Qty: 1
...Autozone's cable..
Specs...
Price:$21.99
Part Number: 01436
Weight: 1.05 lbs
Notes: Negative type 4 gauge; 2 wire lead; 49" length; top post; ring and quick connect terminals OE exact fit style.
Description: Top post with 2 leads, ring and quick connect terminals
Gauge: 4
Length:
49 in.
Shipping Information: Overnight and Two Day shipping are not available for PO Box, APO/FPO/DPO or US Territory addresses.
...Note the connections to the motor and frame mounts are different material as well as length..The price difference of $5 for in stock or same day in store pick up compared to 2-5 day wait on special order, and an inch difference in length to me is a wash...
...While the brand Lynx from AZ is an American brand that you have to special order from them, Napa keeps theirs in stock in store or at a nearby warehouse..AZ would rather sell you their Duralast and Duralast Gold products at a cheaper price and that's why they are in stock at their stores...
...Side note...The brand new Duralast gold Starter relay ($20 and best AZ had in stock) that I had just installed when I swapped my pos/cable and new high torque starter lasted 42 days...I was gone out of town for 21 days and the truck was started 5 times in the remaining days...:thumbdwn:..I threw in my old motorcraft relay and it's good to go...
...I am not bagging nor saying that Napa is the ultimate place to get a battery cable from but, when comparing apples to apples and keeping price, availability, and long term maintenance in mind while taking the cables to each store for comparison, in my opinion, they are easily found to be a quality American made part available when you walk in, the correct length with slack at mounting points, and at a reasonable price..
