91 explorer dies intermittently | Ford Explorer - Ford Ranger Forums - Serious Explorations
Epalm18
Eureka, CA
91 Ford Explorer
Still can’t figure out my 91 explorer. It will idle about 5 minutes then die. I can go drive it and it dies intermittently then fires right back up on side of road. It has codes 87 and 95. I did hook a fuel pressure gauge to it and it does not lose fuel pressure when it dies. Things I have replaced include: fuel pump, canister purge valve, throttle positioning sensor, computer, fuel filter, spark plugs, plug wires, fuel pressure regulator, fuel pump relay, and made sure fuel cutoff switch was good and checked for corrosion at fuse box. Getting very frustrated any more ideas???
ChildIdenticant
california
1994 explorer
Can you show the kind of guage you are using? Or at least answer : After removing the guage from the test port, does it maintain its reading unless you reset it?
Epalm18
Eureka, CA
91 Ford Explorer
It’s a screw in type so if unscrewed it the gauge would lose pressure
chevyh8ter
97 ford explorer
I believe there is a ignition module in front of the battery. My old Tbird would cut off when it got hot. It was the TFI type, not sure if the new modules experienced this too.
Epalm18
Eureka, CA
91 Ford Explorer
Yes I was wondering if that could be it. Just hadn’t heard of it being a common problem. Might throw one at it, just tired of throwing parts at it.
chevyh8ter
97 ford explorer
I had mine tested at my local auto parts store for free, (Adanced Auto Parts). He told me I was the first person to ever have one tested.
EDIT: One thing I'm not so sure of, the test may not be so thorough. I say that knowing my old Tbird TFI module would work fine while it was cold. It only failed when it got hot. Hence why Ford relocated them from the distributor to the firewall. That said, I never swapped my Tbird module, I just relocated it away from the engine heat and it work fine until I sold the car years later. The Explorer module is beside the radiator,....who knows ?
Epalm18
Eureka, CA
91 Ford Explorer
I’ll look into it. I wonder what the procedure to test it is from home?
prince402
South Florida
1994 Eddie Bauer
I had a problem like that until I replaced the ECM relay with a good one. What a relief after living with it for weeks and having it die on me at any time. After 5 minutes or so it would start up and run fine until it died the next time.
chevyh8ter
97 ford explorer
Can you be more specific ? ECM, Engine Control Module-relay ? Thats a generic term, in my opinion.
EDIT: Let me guess, thats what your mechanic told you the problem was.
prince402
South Florida
1994 Eddie Bauer
It's in the same fuse box as the fuel pump relay that you've already replaced.
Epalm18
Eureka, CA
91 Ford Explorer
So there’s the Ac Relay, Fuel pump relay and EEC relay in that box. I’ve replaced the EEC and Fuel pump relay. Where is the ECM relay located?
prince402
South Florida
1994 Eddie Bauer
The ECM is the same as the EEC. It goes by both names which can be confusing.
Engine Control module.
Electronic Engine Control.
Be sure the new relays are good that you put in. If you're sure they are good, you've covered it.
Read the engine error codes, if any. That might give you some direction. It's the old OBD1 system but it can still be helpful.
On my 94 EB, it was the relay in 2012. When it happened again in 2019, I checked the relays and they were good. It turned out to be actual ECM. Unfortunately the old OBD1 error codes didn't nail it down to that. As a long shot, I got a salvaged one and it eliminated the stalling problem. You can get a rebuilt one for around $100.
The good news is that it is located behind the right panel of the passenger footwell and can be replaced in about 15 minutes.
