iammike
- August 17, 2005
- Roanoke,VA
- 91 Mazda Navajo
I've had to have my Navajo towed home twice in the last month. Each time I had stalled at a traffic light. I could restart the engine fine, but when putting it in gear it would lurch a foot or two and then stall. It's a 91 with automatic transmission and about 90000 miles. If I jacked up the rear end, I could put it in gear as long as the brake was not on. I was able to get it running the first time by changing the transmission fluid. I don't think it had ever been changed before, and was a nasty brown color when I drained it. After changing it I ran it through the gears with the rear end jacked up and everything appeared fine. I drove it for about a week and put about 100 miles on it and then without warning the same stalling problem happened again. I changed the transmission fluid again, and its now its driveable once again. I know that you only get around half or so of the fluid with each change, so I suppose that there may have still been enough crud in there after the first change to cause the problem. But I don't really want to go through this process again and have it die in another week. I'm also giving serious consideration to selling it, and want to be honest with potential buyers. Could changing the fluid again have solved the problem or am I just bandaiding a much more serious issue? Any thoughts or suggestions would be greatly appreciated.
