91 Ranger 4.0l Manual Transmission | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
310rm
1991 Ranger XLT 4.0L
Hi,
I had to replace the slave cylinder on my Ranger. Had to drop the tranny to get to it. In order to drop the tranny, I separated the transfer case from the transmission and when I was got them separated, I noticed a very thin, now mangled washer lying on the driveway. Ford dealership wasn't able to tell me what it was. Their best guess was thrust washer. I don't think it's a thrust washer. It's very thin and completely flat. the thrust washers I've seen in researching this have all been fairly thick and have staggered curved lips on them. I can see a ring around the one bearing retainer nut that may be an indication of where I washer might have been. Does anyone know what this washer is and do I really need it in order to put the transmission and transfer case back together?
Any help is appreciated.
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
310rm
Hi,
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Looks to me like the washer from the shifter bushing. You most likely removed the stick shift before dropping the trans, maybe that washer fell on the ground without you noticing.
310rm
Hi Bill,
I did remove the stick shift before dropping the trans. Is that bushing a necessity, or can I get along with out it? I've had a heck of a time trying to identify it but was thinking it came from the trans, so maybe that's why. I don't like doing things half-***ed but if I can't find a replacement am I doomed without it?
Thanks
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
It's readily available. This is an Amazon pic, but your part stores should have one. That spring is in lower right.
I'm not guaranteeing that's the part you found, but it sure looks like it from here. Take it to the store and hold it up to the kit spring to be sure.
310rm
That looks exactly like it. Thanks so much! I appreciate your time and help, Bill.
Have a good one
Jessemordecaijones
Lake forest california
1991 ford explorer sport
Hey i have a quick question for you. How did you get to the top trans to motor bolt on driverside ? Its my last bolt inorder to drop the tranny on my 1991 explorer sport 2wd 5spd manuel and im about to pull the wheel off and the inner wheelwell dust and debris insert off so i can try and get at it from there? Anything you might know would be helpful thank you
roscoe 0202
salt lake city utah
1999 explorer sport
in my bronco II I get the top two bolts from the top much easier.
roscoe
