91 rear pass door handle won't work | Ford Explorer Forums - Serious Explorations
KlimFord
Location
Rocky Mountain foothills
Colorado
'91 Eddie Bauer 210K
For years the rear passenger door handle hasn't worked. It moves freely but doesn't release the latch. Exterior handle works fine, although requires a lot of pull.
I've got the the panel off ready to replace the cable window mechanism with an arm-type from Kbabiak and figured this is the time to finally fix the latch. Every thing appears to be connected from the handle to the latch (from what I can see and having no schematic).
Has anyone had this interior latch problem that can give me some pointers? Thanks.
It's a common problem.
The Front Passenger and the Rear Driver use the same interior handle. Just as the Front Driver and the Rear Passenger use the same handle.
There is a little plastic gear that operates the actuator rod. The teeth on the gear break easily.
Get one from a Junkyard Most of the time the door panels are already off, and it is just 1 or 2 phillips screws holding it in.
Ryan
