'91 X with Code 22 | Ford Explorer - Ford Ranger Forums - Serious Explorations
'91 X with Code 22
rguy
Republic of Texas
'91 Explorer 4x4
I just completed a manual to auto trans swap including a new/used ECM for a '91 with an Auto Trans. Now I'm getting this code, along with a couple others. Prior to the swap, I wasn't getting any codes. Code 22 is: MAP (vacuum) or BARO signal out of range - MAP. What is this telling me and how can I fix it? Where is the MAP sensor?
Thanks.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
rguy
Republic of Texas
'91 Explorer 4x4
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
On a '91, it's a BARO sensor, meaning that it isn't hooked up to the manifold. It's simply a pressure transducer that tells the computer what ambient air pressure is.
Check the wiring between the PCM and the BARO sensor. The BARO sensor's output is a frequency, so you'll need a DMM with a frequency counter to check the BARO output.
